Swaybar help!
Old Oct 6, 2008 | 06:32 PM
sachin_04OB's Avatar
Swaybar help!
hey buddies...I have a 2004 G35 coupe 5AT. I hear a clunking noise from the rear at low speeds over bumps! the Stealership told me i need to replace the sway bar end links and are charging me $188 which I am pretty sure is high!! any suggestions?? or should I just get a custom sway bar kit! anyone from michigan who can help with install!!! let me know...thanks!
Old Oct 6, 2008 | 07:15 PM
NismoG35S's Avatar
rear sway bar links are pretty easy to install and are not a major problem. altough that price isnt that bad probly charging you 1hr install plus the parts. IMO do it your self on the weekend jus make sure you have both rear wheels in the air at the same time or you will have fun tryin 2 get them in. if im not mistaken.. the 2 bolts on either side that mount to the control arm are 14mm and the 1 nut to the sway bar is 14mm pretty quick job overall. have fun gl
Old Oct 6, 2008 | 07:26 PM
thanks a lot for the help! is it worth the effort to just install a custom sway bar kit?
Old Oct 6, 2008 | 07:31 PM
NismoG35S's Avatar
replacing the entire sway bar plus the front isnt really easy at least not on the ground. if you want to upgrade i guess now is a pretty good time since ur spending money to fix the same system. every break down is a chance to upgrade right?.gl
Old Oct 6, 2008 | 07:33 PM
ttrank's Avatar
Grocery getter
It's a very good idea to get better sway bars and links but you can just buy the end links to fix the problem. Aftermarket end links are nice to have sice the G's are not the best.
Old Oct 6, 2008 | 07:38 PM
NismoG35S's Avatar
^ ditto do like me im gettin the nismo sways jus for the name mostly 8-)
Old Oct 6, 2008 | 08:16 PM
I totally agree!! thats precisely why i wanna get the swaybar kit itself!!! how much is the nismo kit? I was thinkin of the eibach one!
Old Oct 6, 2008 | 09:05 PM
NismoG35S's Avatar
i rather not say my price but the nismo catalog msrp says 500. for front and rear with bushings.. i dont think it evencomes with links lol
Old Oct 6, 2008 | 09:09 PM
oh..alright...i`ll take a look! thanks a lot!
Old Oct 6, 2008 | 10:44 PM
V35 Skyline GT's Avatar
6MT Coupe
My Cusco's didn't come with links either.
Old Oct 7, 2008 | 08:50 AM
JZ39's Avatar
It's the links.
You can buy new ones for like 15$ each from Riverside Infiniti sponsor.
The current ones are redsigned from the 04s and beefier. I have never had problems with them since I replaced them.
Old Oct 7, 2008 | 09:08 AM
Thanks JZ39! I was thinkin of gettin the eibach sway bar kit instead! but i will look into the option of gettin the links from riverside! thanks man!
NailBomb
Oct 28, 2015 07:53 AM
SIKKI
Steering & Suspension
Sep 16, 2015 01:14 AM
dorkstar
Sep 16, 2015 01:02 AM
