WTF stupid Infiniti and their spare tire.
Old Nov 30, 2008 | 07:26 PM
  #31
NyG35fL's Avatar
Originally Posted by wxp-g35
im aware they are staggered. if we can use a donut on the front and rear why cant they just make a spare the same size as the front wheel? it wont matter if its staggered because my wheels dont unstagger themselves when i install a dinky donut...
dinky donut
Old Nov 30, 2008 | 07:29 PM
  #32
OnE BaD G35's Avatar
Can someone post a picture of what im supposed to be looking for? My car is parked at a friends house and if i could get the spare on that would be awesome so i could bring it home.
Old Nov 30, 2008 | 07:36 PM
  #33
filthyg35's Avatar
having the dinky donut is ok, but the jack is a killer..it sure is hard to get under the frame, I bloodied up my knuckles a few times hitting the pavement while trying to turn that damn jack..lucky I didn't get the aero kit..what happens then? that jack would never fit under the car.
Old Nov 30, 2008 | 08:09 PM
  #34
wxp-g35's Avatar
why is everyone having trouble with the jack. i thought it was pretty simple. slide jack under car and turn. u have to put the rod in the hole to turn it. and it grabs the frame very easily. as for the spare. they put the dinky donut in there to save weight? yet theres some people talkin about keeping a floor jack in their trunk that weighs more than one of our normal size wheels. F the dinky donut. i want a full size. i dont trust the donut. i thought i was gonna die when i had it on my car...and when the h3ll am i gonna keep 2 golf bags in my trunk? wtf? thats what they're concerned about? ok im done...
Old Nov 30, 2008 | 09:19 PM
  #35
Darkstar752's Avatar
^^^Because a full-sized spare is a permanent replacement. My friend blew a tire on his TL and he just put the other one on for good since all 4 are the same size.
Since they are staggered, your gonna need a new tire anyway. it's gonna be temporary whether your running 2 front, 1 rear and a donut, or 3 fronts and 1 rear. So why would they give you a full-sized tire. It would make absolutely no sense to. It would be more expensive on both ends for the same temp. fix, and not to mention that you need to include the proper rim size 17", 19".
Old Nov 30, 2008 | 09:27 PM
  #36
mateuszkedzier0's Avatar
i have brembos and about 2 weeks ago i got flat and i did't have any problems it fits 100% sure
Old Nov 30, 2008 | 10:04 PM
  #37
can someone post a picture of a spare that clears the brembo calipers? i would like vo compare it to mine
Old Nov 30, 2008 | 11:28 PM
  #38
jonahlw's Avatar
spare tire works fine
Old Dec 1, 2008 | 12:11 AM
  #39
NismoGirl2001's Avatar
Ah, this is one reason having a sedan with a full sized alloy wheel spare is nice. Hopefully I will never have to use it, but it's there if I need it.
Old Dec 1, 2008 | 11:54 AM
  #40
GR8TG35's Avatar
Originally Posted by OnE BaD G35
damm, what could i have done wrong? I didnt notice any "bolt" on the inside of the spare and im positive that the caliper was definately not letting the wheel clear. Im not sure what it may be.
The bolt I was referring to is not on the spare tire, It should be on your front rotors.......Its an 8mm bolt and sleeve type spacer. They put them on so you can not put the rear tires on the front. The front OEM rims have a space that allows the rim to sit flush. If you were to try and put the rear on, it would not sit flush....
Now, if you look at the back of the spare, there may be a slot for that bolt to fit properly. Thats all I can think of.
Old Dec 1, 2008 | 12:09 PM
  #41
^^Hit the nail right on the head! Thanks alot everybody, this is really embarrassing but everyone makes mistakes right? Either way thanks again.
Old Dec 1, 2008 | 12:27 PM
  #42
nghiars's Avatar
my spare worked fine... it's actually the funniest looking spare i've ever seen since its only 185 mm wide but the metal part sticks further out than the tires due to clearence for the brembos.
Old Dec 3, 2008 | 01:40 AM
  #43
punjabihothi's Avatar
hmm same thing happened to me..it wouldnt fit at first but after like 25 mins of trying i worked..it happened to my front right tires and i do have brembos..i have a 2004 g35 coupe..
Old Dec 3, 2008 | 07:30 AM
  #44
vhtran's Avatar
Kinda unbelievable, maybe OP did something wrong? I don't think ppl that can design a well running car can not design a donut that fit for the car. But does make me want to try the donut on my next oil change! =)
Old Dec 3, 2008 | 08:17 AM
  #45
wyldfyer's Avatar
Dang. Sometimes it seems like ppl jump on the forum before they even call Infiniti, lol. Thats respect right there. Infiniti would have been quicker though. I remember my encounter with that spacer and bolt. I had just gotten my wheels and I put the back on first. When i went to mount the front, I felt SOOOOOOOOOOOOO used. I remember thinking how it was too good to be true when I first got my wheels and now they dont fit. I actually decided to take the bolt off without even having knowledge of what it was for, lol. I think it also helps keep your rotor snug but that doesnt matter as long as you tighten your lug nutz. Glad to see I didnt take off something that was THAT important. I drove paranoid for a few days though, lol.
