2006 Head and TAil light compatibility
Old Dec 5, 2008 | 12:57 PM
jesseyoo's Avatar
I have a 2003 5AT G and I wanted newer head and tail lights. Which year is compatible and which ones should i buy? Are clear corners the better way to go?
Old Dec 5, 2008 | 01:27 PM
Darkstar752's Avatar
Just buy some 06' head and tail lights off eBay or something. The headlights will probably be recalled, so all you have to do is adjust the aim of the light down to specs.
All you do is take out the old ones and plug in the new ones. You can re use your ballast for the headlights.
Old Dec 5, 2008 | 09:25 PM
Beebo's Avatar
^+1 The newer 06-07 heads and tails are plug and play
PM mike@riversideinfiniti he can help you out with all your questions
Old Dec 8, 2008 | 04:13 PM
jesseyoo's Avatar
the new 06-07 headlights, they will be recalled?
Old Dec 8, 2008 | 04:15 PM
Hotdawwgman's Avatar
the new one shouldn't, unless someone sells you a recalled 06 headlight
Old Dec 8, 2008 | 04:30 PM
jesseyoo's Avatar
how much do they go for? a pair that is and where could i buy it? im really new to all of this
Old Dec 8, 2008 | 04:31 PM
jesseyoo's Avatar
should i just go with clear corners?
Old Dec 8, 2008 | 05:06 PM
Clear corners and projector headlights are 2 completely different things...
And if you buy recalled headlights, all you need to do is adjust the aim by yourself, which is just twisting a screwdriver on the adjustment screw in the headlight to lower the light down. There's a DIY for it on this forum.
Old Dec 8, 2008 | 07:05 PM
Beebo's Avatar
^+1
https://g35driver.com/forums/exterio...g35-coupe.html
roboeclipse
Lights
Aug 13, 2015 10:45 PM
underworld
Aug 6, 2015 01:36 PM
mcneil_g35
Lighting
Aug 5, 2015 01:09 PM
myaso
Lighting
Jul 22, 2015 10:34 PM
