Help - 225/40/18 Tire Fitment?
Old Dec 11, 2008 | 09:11 PM
synn's Avatar
I'm buying barely used winter tires, the tires are 225/40/18 all around. I am assuming that they will fit, but I just want to confirm before I buy the tires and find out the hard way.
I have an 03 coupe with brembo's.
Also I heard that staggered fitment helps with VDC? Is there truth to that? & if so, how much does it help?
Old Dec 11, 2008 | 09:15 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
NO! those are smaller than the stock diameter tires, i wouldn't even put that size on a sedan. having that front and rear has a good potential to screw with your VDC.
Old Dec 12, 2008 | 12:25 AM
synn's Avatar
ehh damn, thanks for the advice. I appreciate it.
guess i'm still on the hunt for a winter setup.
Old Dec 12, 2008 | 12:36 AM
Glex25's Avatar
Administrator
There is no problem running same size tires.
I run same size tires @ track events(275/35) all around.
I believe he might be asking if its k to run that tire size
for winter tires.
You don't want wide tires when you want to cut through the snow.
I don't see no problem him running 225 all around as long as the rims
aren't wider than 8.5,9.0 max.
Old Dec 12, 2008 | 08:26 AM
GR8TG35's Avatar
The stagger set up on are cars is one inch taller and 1/2 inch wider in the Rear.
I run four of the same size in my winter set up, and its fine. My tires, however are within 1% of the OEM rear diameter. My Stockers are 245/45/18 rear, and the snows are 225/55/17, so both diameters are about 26.8". Your 225/40 is about an 1 1/2" smaller, so I'm not sure if that size sidewall will cause your VDC to screw up.
Four the same is no problem, just make sure your diameter is within specs of the stock rear tire.
Old Dec 12, 2008 | 09:25 AM
synn's Avatar
I appreicate the replies guys.
So it's okay to run the same size tires all around..
but in conclusion, should I get the 225/40/18's or pass on them?
Old Dec 12, 2008 | 10:44 PM
for winter tires.
you most certainly are correct, there is no problem with running the same size tire all around on a coupe. I was kind of leaving myself open for someone to argue, i was being short with the OP so he could search why they wouldnt work.
I agree that a 225 should and can be used all around for snow tires. But he should be running a 225/45 all around as opposed to a 225/40 which is much shorter than stock, especially in the rear.
-GP-
Old Dec 12, 2008 | 11:20 PM
Glex25's Avatar
Administrator
^ correct profile should be 45 instead of 40
Thanks I overlooked that part of the description
Old Dec 14, 2008 | 05:41 PM
mmmk's Avatar
during the winter, i run 245/45/18 all around on my stock rims.
VDC works normally...
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
socaldavid
Sep 5, 2015 04:35 AM
