Oil the Weatherstripping??
Old Jun 4, 2004 | 09:45 AM
kroams's Avatar
I have noticed that when my window goes up and down when I open/close the door, it doesn't sound like its smoothly moving through the weatherstripping.
Should I just spray a little WD-40 on the weatherstripping to help it slide better? Is oiling that something you regularly do?
2003 G35c/5AT/BS-Graphite/Prem/Aero/Splash/NISMO sway bars/JWT Popcharger/Z-Tube
Old Jun 4, 2004 | 12:35 PM
gto2050's Avatar
Re: Oil the Weatherstripping??
Absolutely not! That will just streak your window and make a gernal mess. Sounds like time for a warranty call.
Old Jun 4, 2004 | 03:09 PM
nate1749's Avatar
take it in, they put some lubricant on the tracks of my old car windows and that seemed to do the trick.
Old Jun 4, 2004 | 04:24 PM
kroams's Avatar
I am only talking about the weatherstripping at the top (near the roof). The window goes up and down fine, but when you close the door and it goes up that 1/2 inch, it sounds like it isn't going in smoothly. I hear the same sound when I open the door.
The passenger door sounds fine, only the driver's door makes a strange rubbing noise. I thought putting a little WD-40 just in that area at the top of the door would help it slide in-out better.
Old Jun 4, 2004 | 04:51 PM
tpware's Avatar
you want this
http://www.autopia-carcare.com/1z-914805.html
your local BMW place carries it, but its $17 retail. This place will have it to you in about 3 days. This stuff is lasting much longer than 3m silicon spray. And its not nasty like silicon spray.
Old Jun 4, 2004 | 05:48 PM
bsoo's Avatar
YOU DO NOT PUT WD-40 ON PLASTICS!!!!!
Bad idea.
http://www.imagestation.com/member/?name=bsoo
2004 Coupe 6MT fully loaded incl. side moldings and splash guards, but no satellite radio.
Old Jun 5, 2004 | 12:40 AM
G35_4EVR's Avatar
Just use Meguiars Vinyl and Rubber cleaner/protectant. It will keep your rubber moldings from drying out and cracking and should eliminate the noise you're hearing when the window travels the 1/2 inch when closing the door. I've been using it for the past 5 years on my BMW and now I use it on my G.
2004 Coupe/DG/Graph/5AT/Premium/CB/Tint and CG Baby!
f22raptor
Mar 18, 2016 08:50 AM
prinny
Nov 22, 2015 11:07 PM
mbe32
Nov 13, 2015 11:09 PM
9tray turbo
Sep 29, 2015 10:22 PM
