Installed Z-tube pop charger and Service engine light came on
Old Dec 23, 2008 | 10:13 PM
Maxypad's Avatar
I was just wondering why the Service engine soon light came on i didn't mess with anything. And what should i try to do???
Old Dec 24, 2008 | 12:22 AM
MTG35guy's Avatar
Mine did the same thing when i installed my CAI, i reset my ecu and it went away and hasn't come back. Try that.
Old Dec 24, 2008 | 12:39 AM
Xet's Avatar
Xet
search...
https://g35driver.com/forums/g35-cou...e-install.html
just one of many
Old Dec 24, 2008 | 01:41 AM
SixOneFive's Avatar
Make sure you put the MAF sensor back on.
Old Dec 24, 2008 | 02:34 AM
tango5o4's Avatar
did you remember to reconnect your vacuum line?
Old Dec 24, 2008 | 08:15 AM
viceversa's Avatar
Mine came on after install too, didn't have everything tight enough. so go back and check to make everything is snug.
Old Dec 24, 2008 | 08:39 AM
fishhouse's Avatar
do in order:
1. unplug your neg battery cable for 12-24 hours
2. wait and see if it comes back on.
3. if it does, take to a stealership or any little parts store (not sure what you have in your area...but like Advance Auto, NAPA, PepBoys, etc) and they will pull the code for you - remember the digits.
4. go to Infinitihelp.com to see what the code is for.
then come back with more info.....
Old Dec 24, 2008 | 10:16 AM
viceversa's Avatar
You dont necessarily need to keep the battery unplugged for 12-24 hours. I unplugged mine for about 15 mins and all is well.
Old Dec 24, 2008 | 10:41 AM
Maxypad's Avatar
thanks guys im just freaking out cause im 19 and just did my first mod ever and saw this and its been freaking me out
Old Dec 24, 2008 | 10:53 AM
Bigd2k6's Avatar
you've ruined your car!!!! j/k.
Old Dec 24, 2008 | 11:30 AM
viceversa's Avatar
I was in the same boat as you, 19 and first mod ever was pop charger and z tube. what's next on your list?
Old Dec 24, 2008 | 02:04 PM
gary c's Avatar
Knowledge is power....read the instructions, beats opinions!
When I received my Stillen CAI/Z-Tube the instructions said to remove the
negative side of the battery, (yes I read instructions) and I didn't have any
issues. You only need to remove the battery cable for a short amount of
time, any longer than an hour and your wasting your time.... It's
amazing some of the advice you receive here on Driver!
Gary
Old Dec 24, 2008 | 03:42 PM
fishhouse's Avatar
^ my previous car was a maxima and i was told by my service department to disconnect overnight -hence my statement.
great if it does it quicker. but 24 hours will not hurt anything...short of "wasting your time" perhaps.
Old Dec 24, 2008 | 06:04 PM
uf20wop's Avatar
high idle code probably
Old Dec 24, 2008 | 06:33 PM
indyjrt's Avatar
Wow, you are a lucky kid (I can call you kid because I'm 39 and I don't personally own a "G" , my wife does)
Don't be afraid to try things, when things break or don't work right, be a problem solver, read the forums and look for help.
