Service engine soon light after intake install??
Old Sep 27, 2003 | 04:56 PM
hyperxmr2's Avatar
i just installed the Pro-1 cai intake and now my service engine soon light is on. is that the same as a check engine light? does having the sensor flipped around( was on right side now on left side) have anythign to do with it?im going to pop the stock intake to see if it stays on. also i started the car with the sensor unpluged by accident, may that have somethign to do with it.
Old Sep 27, 2003 | 05:54 PM
redwillow's Avatar
20 Year Member
Re: Service engine soon light after intake install??
uhhhhh.... yeah, if you started it with the sensor unplugged that will cause it to set a code. Someone else did that on here, just disconnect the neg battery cable to reset the computer and you should be ok.
I think the other post was in Technical forum a few weeks ago.
03 6MT coupe, red/willow, premium, aero, splash guards, alum pedals, clear corners, 15% tint
Old Sep 27, 2003 | 08:09 PM
gould2000's Avatar
I believe if you even have the bettary plugged in and unplug the MAS/MAF sensor, that will trip the light. The car may start without the MAS/MAF plugged in, but will stall since no air is sensed coming in. Do an ecu reset and you'll be all set.
Old Sep 27, 2003 | 08:56 PM
hyperxmr2's Avatar
thanks guys, doing the 12 hour disconnect battery as we speak. i actually did a test run with the light on and the car seems to be slower then stock. like the computer wont let u punch it. hope the reset fixes all this thanks again
ghost_g35
Aug 7, 2015 10:31 AM
newg37
Jul 26, 2015 09:32 AM
ClwMike
Jul 23, 2015 12:55 PM
igking
Jul 19, 2015 01:12 AM
mjfenix
Jul 17, 2015 02:07 PM
