HELP!!! P1124 Throttle Control Motor Relay
Old Dec 25, 2008 | 09:54 PM
specialist's Avatar
Angry HELP!!! P1124 Throttle Control Motor Relay
I couldn't start my car today. i just tryed my car and it turn over and stayed on. I got a obd2 read and i got a P1124 what does this mean??? I did a search and i got nothing??? Please help!!!!
Old Dec 26, 2008 | 12:34 AM
eurodre's Avatar
P1124 Throttle Control Motor Relay Shorted
Old Dec 26, 2008 | 08:52 PM
specialist's Avatar
so what does them mean how do i fix it should i just wipe out the wipe the code out then start to drive it???? or what part do i chnage
Old Dec 26, 2008 | 09:46 PM
eurodre's Avatar
id say go to a mechanic or ur dealership
Old Dec 28, 2008 | 02:32 AM
specialist's Avatar
So I guess you dont know how to fix it then? Does any one else have any other ideas?
Old Dec 28, 2008 | 12:31 PM
GR8TG35's Avatar
if eurode is correct....then you need to trace the source of the short. Did you do any mods or modify the wiring in any way? If not, then your control motor could have gone bad. Is your car still under the power train warranty?
Old Dec 28, 2008 | 01:09 PM
crashnburn's Avatar
when i cleaned my throttlebody bout 2 years ago,ii had this same problem, i had to do the idle relearn like 200 times b4 it took and was right again..... i even took it to nissan and they ran the consult 2 program and it didnt work either..... you can get a new TB
Old Dec 28, 2008 | 03:17 PM
LjN_728's Avatar
I had the throttle control relay short on me about a yr ago...since it was under warranty, dealer replaced it. Apparently it's a very common occurance, according to the dealer.
Old Dec 30, 2008 | 08:34 AM
specialist's Avatar
I found the short it was the ipdm i was getting voltage when i was not suppose to get voltage thanks for everyone help
Old Dec 30, 2008 | 10:42 AM
maciejk's Avatar
what is an ipdm?
Old Jan 9, 2009 | 06:05 PM
djkace77's Avatar
I just got this code as well how did you fix it?
Old May 20, 2009 | 05:13 PM
SwansG35's Avatar
So, did you replace the IPDM?
Hasanbaloch
Feb 29, 2024 08:45 PM
junon
Jan 14, 2023 09:37 PM
Z1Motorsports
Suspension-Vendor
56
May 31, 2020 01:56 PM
broke_as_ajoke
Aug 22, 2015 08:27 PM
justgotg35
Jul 19, 2015 12:33 PM
