Grinding Noise... NOT ABS
Old Dec 27, 2008 | 10:01 PM
WhosRich's Avatar
i drive an 04 coupe with 36,000 miles. i just started to notice a grinding noise coming from what sounds like the front driver side.
i would describe the sound as like an ungreased hinge so to speak. i even feel it through the steering wheel, and especially at slow speeds. anyone got any ideas about what it is? id appreciate any kind of feedback at this point.
oh yeah, nissan said i needed new rear brake pads and rotors. i dont think this is it because the sound is coming from the front. any input?
Old Dec 27, 2008 | 10:33 PM
phatbuddha's Avatar
What...you don't have any brakes in the front?
Old Dec 27, 2008 | 10:54 PM
WhosRich's Avatar
lol. i have brakes in the front. they were replaced about 7k miles ago. they were worn out before my rears were. after some careful searching, im starting to think it a compression rod. any ideas?
Old Dec 27, 2008 | 11:25 PM
phatbuddha's Avatar
Not without hearing it. It could be anything.
Old Dec 28, 2008 | 12:27 PM
GR8TG35's Avatar
Look at the obvious first...does the sound or vibration go away under braking? If so, chances are it could be a front wheel bearing. They were notorious for over tightening at the factory in 03-04. If it still happens, maybe they didn't do to good a job of resurfacing the rotors.
If the work is guaranteed, take it back and let them fix it.
Old Dec 28, 2008 | 12:30 PM
Hotdawwgman's Avatar
The compression rods will create a crunching sound especially over slow speeds, like speed bumps!
Old Dec 28, 2008 | 12:31 PM
wxp-g35's Avatar
check your power steering fluid
Old Dec 29, 2008 | 03:21 AM
WhosRich's Avatar
thanks for the tips guys. ill update when i find out the cause.
Thebaws11
Jul 2, 2021 11:36 AM
magnetism80
Feb 1, 2019 10:00 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Thebaws11
Nov 30, 2016 12:54 PM
alinero718
Sep 27, 2015 09:35 PM
