Please help a fellow 03 coupe g35 owner!
Old Jan 5, 2009 | 01:21 AM
jerryG45's Avatar
I guess the best thing to do is run a test by switching the ignition but not turning it on and see what lights and does not light..
1. Is there any type of indication for the passenger side not wearing their seat belt?
I noticed that when they are not wearing their is no sign of them NOT wearing it, I only notice by turning and seeing that they are not wearing it.
From what I have read so far there is only an indication for the driver so far.
If I am wrong please advise me.
2.Does this affect the air bag? Is there an indication when the passenger airbag is on/off?
I will do the ignition test.
3. There is a latch behind the passenger seat, it does not do anything . I thought it would push the seat forward but it does not. Is this what its suppose to do? can it be fixed?
I am going to try harder as Elayman has suggested.
4. I have the g35 with the flat center console, can I someone upgrade this to the armrest?
This is a yes and can be found at www.everythingg35.com
5. Im thinking of buying rims for my car, 18s. Any recomendations for a red. Ill post a picture as a reply.
still taking suggestions
Old Jan 6, 2009 | 12:00 AM
conq's Avatar
Dunno about a button on the seat. In my 03 when you pull the latch up the seat moves forward by itself(like pulling the latch on the right of the seat).
Download the manual.
https://g35driver.com/forums/faq-diy...df-format.html
Extract the files and open se.pdf. Page SE-57. You'll see the cable that should be connected to the latch.
On SE-58 you'll see the reclining lever ****. There's a cable that goes from the latch in the back to the reclining lever.
Page SE-55 parts 1,5,12,18 is what you're interested in.
Make sure cable is connected in both ends.
Old Jan 6, 2009 | 07:28 PM
jerryG45's Avatar
Thank you, thas perfect.
Old Apr 6, 2009 | 09:54 AM
gcoupe_toronto's Avatar
is it possible to buy just an armrest and it would fit the early 03 center console?
nervseele
Engine - Exhaust
Jan 17, 2016 01:02 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
teamghost
Jul 28, 2015 04:52 PM
laksjd84
Jul 24, 2015 05:12 PM
mjfenix
Jul 17, 2015 02:07 PM
