Clicking noise?
Old Jun 9, 2004 | 05:46 PM
G35Art's Avatar
Clicking noise?
I hear a click as I start driving. It is only one click, then again when I slow down or speed up. It sounds like its coming from the right side, possibly the suspension. The sound doesn't occur when a go over any bumps. Any ideas what this could be? The car drives normally and the sound was probably like that for a while i just noticed this recently while driving with the windows down. Any info would be appreciated.
Old Jun 9, 2004 | 08:09 PM
RaySur350GT's Avatar
Re: Clicking noise?
Sounds like your axle bolts are loose in the rear. Have them tightened at the dealer. Under warrenty too.
- Don't argue with idiots. They will bring you down to their level and beat you with experience.=P-
Old Jun 9, 2004 | 08:21 PM
StrictlyG35's Avatar
Re: Clicking noise?
I have the same clicking noise outside of my car which i noticed when the windows were down. I will get it checked out on my oil change service
Old Jun 9, 2004 | 10:00 PM
G35Art's Avatar
Re: Clicking noise?
Thanks. I just made an appointment with the dealer. They couldn't give me an appointment until next wednesday. Is it okay to drive it the way it is?
Old Jun 10, 2004 | 12:54 AM
Canton_G35's Avatar
Re: Clicking noise?
dealer fixed mine with no problems. I was hearing the noise from the right side but they took care of both sides at the same time.
And I was hearing the noise for about a week before I was able to bring it in.
2003 G35 Coupe 6MT/Black/Graphite/15% tint/6 wire GroundingGear™
Old Jun 12, 2004 | 02:36 AM
Re: Clicking noise?
So what was exactly causing the clicking noise?
Old Jun 12, 2004 | 10:51 AM
Canton_G35's Avatar
Re: Clicking noise?
I was told it was the spline on the axle that wasn't seated properly. So they regreased the axle and retorqued it.
Old Jun 12, 2004 | 11:33 AM
zazaracing's Avatar
Team Transport Member
Re: Clicking noise?
I had the same noice its nothing major its from the rear axles they just need to regrease them youll be fine
03 6MT Coupe Blk/Blk> Injen CAI, Hotchkis adj Sway Bars, Test Pipes< "Nt G R8D" Aj
Old Jun 14, 2004 | 05:50 PM
syntro's Avatar
Re: Clicking noise?
I had a problem with clunking sounds coming from the front right of the car on slow left turns. After spending 4 hrs. at the dealership it turns out that they didn't torque my wheels properly when they swapped back my summer tires. Once they re-torqued it it was good to go, no problems. So, if the dealer cannot find anything else, ask them to re-torque the wheels, can save you some time !
G35C 6MT
Old Jun 14, 2004 | 05:57 PM
GlenRoseFireFighter's Avatar
a.k.a. RANDYS_G
Re: Clicking noise?
It's probably your reverberating toggle swindle. I torqued mine down the 75 lbs and it didn't come back. Make sure you torque counter-clockwise!
2 G or NOT 2 G, there is no question!
Injen SES, Kinetix cats, K&N Typhoon, 19" PIAA Super Rozza's (19x9 & 19x10)
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
