Will Infiniti warranty my transmission?
Old Jan 9, 2009 | 02:38 AM
jalilig35's Avatar
Ok I have the JWT Clutch and Flywheel which is new put 8 months ago. And my 5th gear is starting to grind when the car is cold. Also my clutch pedal gets stuck to the ground sometimes or sticks halfway and the clutch makes weird noises might be the throwout bearing. Anyone know for sure that Infiniti will warranty or depending on the dealership? My warranty is about to expire need help! thanks
Old Jan 9, 2009 | 03:34 AM
1SlowSedan's Avatar
I'm pretty sure they will warranty it. Sounds like you need a new clutch slave cylinder, and about the 5th gear grind? They might replace your whole tranny. Don't quote me on that one but pretty sure.
Old Jan 9, 2009 | 03:42 AM
Mr_pharmD's Avatar
that's a toss up and only the dealer can tell u for sure if its cover or not especially when u installed an aftermarket clutch instead of the oem clutch back in... unless the dealer was the one who installed the JWT clutch.
Old Jan 9, 2009 | 04:07 AM
1SlowSedan's Avatar
highly doubt they will void his warranty because of his aftermarket clutch.
Old Jan 9, 2009 | 05:01 AM
jalilig35's Avatar
**** this is what im scared of, them tellin me warranty voided, but this was happening sometimes before i went with jwt
Old Jan 9, 2009 | 05:37 AM
1SlowSedan's Avatar
Don't worry about it, I had a talk with Phillip Tucker service manager at cerritos infiniti. Aftermarket clutch will not void your warranty.
Old Jan 9, 2009 | 03:29 PM
jalilig35's Avatar
Ok thanks even thou infiniti did not install them?
Old Jan 9, 2009 | 03:34 PM
mIKE's Avatar
If the clutch install ruined your tranny, then the shop that installed it is liable. If the clutch is unrelated to your tranny, then it should be warranted.
derres
Aug 28, 2015 03:27 PM
RA081024
Aug 18, 2015 07:03 AM
Team STILLEN
Aug 10, 2015 08:17 PM
newbdriver01
Jul 15, 2015 06:10 PM
