Door Locks & Factory Warranty
Old Jan 10, 2009 | 08:56 PM
blown420's Avatar
Hi Guys,
I just bought a G35.. it has 56k miles on it. I noticed that the door locks seem to be weak. It works most of the time but every once in a while it doesn't lock. it will go half way.. which is really annoying because I have to check that it's locked each time.
Does the factory warranty cover this for free? If so, is there anything else that I should check while I'm at the dealership?
Thanks in advance.
Old Jan 10, 2009 | 08:57 PM
blown420's Avatar
Did/Does anyone else have this problem?
If it isn't covered by the warranty, is it an easy fix??
Old Jan 10, 2009 | 08:59 PM
O HELLA OEM's Avatar
there should be a DIY somewhere.
Old Jan 10, 2009 | 09:12 PM
TofuProductions's Avatar
should be easy fix if the dealer doesn't cover it under warranty (don't see why it wouldn't be though)
Take apart door panel, check to see if there is enough power hitting the switch, if there is, try regreasing the hinges, also it could just be the motor to the switch is going bad so it is being intermittent for not until it actually dies out.
hope this helps some.
Old Jan 10, 2009 | 11:03 PM
blown420's Avatar
thanks for the info. anything else i should check?
i read up on oil leaking into the spark plugs.. i'll do that also. but anything else other than that?
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
G35-R
Nov 7, 2015 01:21 PM
douglas555
Sep 10, 2015 04:48 PM
johnadlertech
Engine - Complete Motors
Sep 6, 2015 12:45 PM
