(Rca) amp question
Old Jan 22, 2009 | 01:59 AM
bukrickay's Avatar
Post (Rca) amp question
I just bought a JL 10w7 sub and JL 500/1 amp. I was wondering how do you run the Rca wire from the amp on the G. Im also keeping the OEM Bose head unit.
I saw a DIY rca split from the rear speakers for 4 door G's but I was was wondering if it was the same thing on the coupe..HELP!?!
WAS also curious if there is rca cables in the back of the head unit or do I need a converter box?
Old Jan 22, 2009 | 09:27 AM
vhtran's Avatar
should be the same, but that way is high outpout to high input. You can try to buy a device called hi-low audio converter.
Old Jan 22, 2009 | 10:02 AM
Xet's Avatar
Xet
check the audio visual forum sticky on the top. many people have wired it without the hi low converter but i had to buy one personally because it sent too high of a signal and sent my amp into protect.
Old Jan 22, 2009 | 08:02 PM
Curt G's Avatar
You can wire the low (pre Bose amp) signal right in to a JL amp and it will work great.
https://g35driver.com/forums/audio-v...g35-coupe.html
Old Jan 22, 2009 | 11:09 PM
duggy's Avatar
WAS also curious if there is rca cables in the back or do I need a converter box?
I have your same exact setup and I followed the instructions in the link below and have had no problems
Old Jan 23, 2009 | 03:04 AM
bukrickay's Avatar
Thanks guys! Hey duggy how did you run the wire did you get a converter? or did you you just wire the rca from the AMP to the speaker wire? I looked at that DIY setup and I ask the guy but he said his is a 4 door Gand it might be different.
hdmark
Apr 29, 2019 04:31 PM
broke_as_ajoke
Nov 6, 2015 11:49 PM
Bean_VQ35DE
Aug 22, 2015 09:56 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Thunderaan
Jul 22, 2015 07:40 PM
