Reverse lights out?
Old Jan 26, 2009 | 03:44 PM
true's Avatar
Reverse lights out?
Anyone run into this problem before? Both bulbs were working fine and one day, they stopped working. I think it is a fuse, but can't seem to find it. I have searched the forum, and used the service manual, but can't seem to find the specific fuse for the reverse lights. The bulbs could be blown, but both at the same time? You would think the fuse would fail before allowing both bulbs to get fried. Any opinions?
Old Jan 26, 2009 | 03:57 PM
0MGHI2U's Avatar
the fuse is located behind the battery.. if you take off the battery cover and than take out the batter you will see a black box.. that is where all the fuses are.. what year is your car.. i can give you a walk through.. its easy
Old Jan 26, 2009 | 05:31 PM
eurodre's Avatar
u dont need to take out the battery, i didnt need to i fit thru to the box in the back juss take the lining around it off and here u go if u still cant find what the prob is
http://www.g35frenzy.com/downloads/2...anual/K/lt.pdf
Old Jan 26, 2009 | 06:45 PM
true's Avatar
I have an 04.
Old Jan 28, 2009 | 06:41 PM
true's Avatar
So the fuse box I need is under the battery?
Old Jan 28, 2009 | 07:16 PM
eurodre's Avatar
NEXT to the battery
Old Jan 29, 2009 | 11:08 AM
true's Avatar
Originally Posted by eurodre
NEXT to the battery
I already went through every fuse in the box next to the battery and the box in the driver's compartment next to the hood release when the problem originally started. No luck, as all of the fuses are good.
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
Kng0fHrts
Sep 15, 2015 05:40 PM
youngdip631
Lighting
Aug 31, 2015 09:13 PM
ghost_g35
Aug 7, 2015 10:31 AM
