Quick intake and spacer question
Old Jan 28, 2009 | 11:13 PM
reservoirdog242's Avatar
I have a 2004 coupe and i'm going to be ordering and intake and spacer this week. I still havent decided between Fujita short ram or stillen(ztube), which one sounds better? Also I'm going to be getting a spacer (Motordyne) and i'm wondering what size and what kind of spacer i have to get ( http://www.motordyneengineering.com/G35.php ). Thanks.
Old Jan 28, 2009 | 11:36 PM
gary c's Avatar
They all sound better than OEM....!
My first choice has always been the Stillen CAI/Z-Tube combo due to the
size of the K&N filter but mainly because it's not effected by heat. Metal
intakes suffer from heat soak which kills HP due to the temp reached under
our hoods. MotorDynes spacers are a great mod, to keep your engine cover
you'll want to get the 5/16" spacer with copper and by pass valve. The
copper and valve will also keep the incoming air cooler well worth the time
to install....Good Luck and Enjoy!
Gary
Old Jan 29, 2009 | 03:05 AM
Gary
Thanks! but i was looking along the line of a short ram intake because it can rain alot up here (norcal) and i dont want to run the risk of hydrolock. Also is the 1/2" too big or is the 5/16 better, is there a sound difference? Thanks
Old Jan 29, 2009 | 03:12 AM
dofu's Avatar
20 Year Member
MotorDynes spacers are a great mod, to keep your engine cover you'll want to get the 5/16" spacer with copper and by pass valve. The copper and valve will also keep the incoming air cooler well worth the time to install...
The copper iso thermal and the bypass valve are both the same things... the copper iso thermal doesn't need to be manually opened or closed like the normal bypass valve would need, and neither really help keep the intake plenum stay cooler - they are both throttle body heater bypass systems. It's the Aramid gasket that you put under the lower plenum that really makes the difference in keeping temps down.
But I can't argue that it is a great mod.
Old Jan 29, 2009 | 03:15 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
The stillen isnt really a CAI. It is placed just as a short ram intake would be in the engine bay, it just has a plastic box surrounding the filter, so it's a "Cold Air Box"
-GP-
Old Jan 29, 2009 | 03:18 AM
dofu's Avatar
20 Year Member
-GP-
The huge intake duct over the radiator turns a box into a cold air intake... Most likely works better than most cold air intakes with the filter mounted under the headlight too.
Old Jan 29, 2009 | 03:46 AM
Thanks for the responses. Which one sounds better the stillen or fujita. Also I also decided to get exhaust and now i'm between Borla, HKS or FI Also is the Jwt pop charger w/ a z tube good instead of the fujita or stillen?
jsimonk
Dec 22, 2023 03:49 PM
Th611
Oct 27, 2015 03:48 PM
wuppiedog
Aug 7, 2015 11:16 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Soumilg
Jul 18, 2015 12:33 PM
