Spacers...Will they slow you down?
Old Feb 11, 2009 | 03:04 PM
eurodre's Avatar
the weight of a spacer is no heavier than a can of coke? i ono about that 1..
Old Feb 11, 2009 | 03:15 PM
lilindienplaya's Avatar
well the ones i have are pretty damn light i guess it depends on the quality of it. i know spacers for diesel trucks are like 8lbs lol
Old Feb 11, 2009 | 03:43 PM
eurodre's Avatar
i have ichiba v2 25mms and they sure dont weigh 8lb but they also arent as light as a coke can.. that wud be bad wouldnt it? if they r really lightweight
Old Feb 11, 2009 | 04:13 PM
no the lighter the better, just depends on the alloy they use. yeah if they use a lightweight weak metal its a horrible thing but if they use aircraft grade light weight aluminum then its a great thing.
Old Feb 11, 2009 | 04:35 PM
eurodre's Avatar
yah das tru but yah to the OP, just make sure the space is still relatively tight on
the ichiba one i have i have to tighten down with a rachet.. its a 19mm head so i suppose it provides more tightening ability
Old Feb 11, 2009 | 05:15 PM
just use threadlock so its on double good thread-lock will reduce the rish of the nuts backing out. I think i may do that.
Old Feb 11, 2009 | 05:30 PM
eurodre's Avatar
^^huh?
Old Feb 12, 2009 | 11:06 AM
TheDude's Avatar
If you use thread lock, then the spaced would NEVER come off...
Old Feb 12, 2009 | 02:13 PM
theres two kinda Permanant (red) and removable (blue)
Old Feb 12, 2009 | 02:37 PM
fishhouse's Avatar
i use thread lock products like Loctite all the time. on hobby R/C cars for example. or even the MD spacer i just installed on my G (as recommended and supplied by MD with their spacers). it's blue in color - and while it makes nuts difficult to remove (which is obviously the point) they WILL come off with enough force. i believe that's what he means.
Old Feb 12, 2009 | 02:42 PM
INF G'd Up's Avatar
ya if you were gonna use loctite then ya use the blue loctite so you can still break the bolts loose so you can remove the wheel spacers or even to check and tighten them
Old Feb 12, 2009 | 04:00 PM
dofu's Avatar
20 Year Member
Old Feb 12, 2009 | 05:36 PM
eurodre's Avatar
ok uhm.. so put this thread lock on the nuts of the spacers.. and if i have to take them off i have to apply a **** load of pressure? why dont i just tighten down the nuts with a lot of pressure? whats so special about thread lock? or do yall not know how to tighten down a nut? i dont get it
Old Feb 12, 2009 | 06:03 PM
INF G'd Up's Avatar
you would put it on the thread of the bolts that you bolt to the hub if you have the built in studs on your wheel spacer, this is just an extra precaution that some people take so that the nuts stay tight
Old Feb 12, 2009 | 06:15 PM
  #30
eurodre's Avatar
ooh ok, well juss have ur local mechanic or w.e. tighten them down with their air gun thingy
chinee
Jun 10, 2024 07:48 PM
magnetism80
Feb 1, 2019 10:00 AM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
9tray turbo
Sep 29, 2015 10:22 PM
