Help! Strange Electrical Problem...is my car Possessed?
Old Feb 15, 2009 | 02:19 AM
JSpec's Avatar
Unhappy Help! Strange Electrical Problem...is my car Possessed?
Hey all...
I have an 03 coupe.....
The other day i turned started my G after driving normally and the VDC and SLIP light came on and stayed on. It drove ok but seemed a bit off and after a a while i noticed the turn signal start to blink sporadically out of tme.
I parked it for a couple hours. When i started it again, the tach and the temp gauge rose and feel quickly, the headlights turned on and off and the dash lights started blinking. The light control would not work, nor would the wipers, the VDC and SLIP light were still on the dash lights were not on and the gear indicator was blank and the Speedometer, tach etc did not fuction. I drove it for a bit but noticed the transmision (its auto) seemed to shift hard (and the car moved slower in idle in reverse or forward) At this point i stopped. I disconected the battery for half an hour, restarted the car and everything seemed to be ok except the check engine light was on. After driving for 40 minutes home the VDC and Slip light came on again. The next morning the tach and temp did the same rise and fall. The strange (stranger) thing is when the key was in the ACC on position everything was fine and functioning normally; it was only when the car was running that it did all this......
Anyone have any ideas or had this happen??
Old Feb 15, 2009 | 02:31 AM
reservoirdog242's Avatar
Exorcism of Infiniti G35
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
newg37
Jul 26, 2015 09:32 AM
Karnicle
Jul 23, 2015 05:08 AM
justgotg35
Jul 19, 2015 12:33 PM
