Flat tire then !?!
Old Feb 27, 2009 | 02:27 AM
jutn35's Avatar
G35 Coupe
Exclamation Flat tire then !?!
OK so coming back from UCI, on the 55 North I got a flat tire. Pulled to the side and replaced with donut and started to drive.the G started to whack out on me. VDC was flashing, SRS light turned on as well as the CHECK ENGINE SOON. After trying to accellerate , it wont let me, I hear Chattering from the engine and it wont go above 1k RPM. It wont let me accelerate. I pull over again, turn off and turn on. Drove fine with VDC off.
WHAT HAPPENED !??!?
Thanks
Old Feb 27, 2009 | 02:35 AM
xXHotelCrazyXx's Avatar
Your VDC is actin a fool with that donut on there. Dont worry, will go away once you get the right size tire back on there
Old Feb 27, 2009 | 02:36 AM
jutn35's Avatar
G35 Coupe
THANK YOU FOR YOUR FAST RESPONSE ! ^ kinda not really thought about it, but i was like it has to be something else
Old Feb 27, 2009 | 03:02 AM
RickyGill's Avatar
thats pretty weird. i had my donut on my G for about 2 or 3 days and i had no problems, only light that was on was the tire pressure light. but hopefully ur car will be back to normal once you get a new tire put on.
Old Feb 27, 2009 | 04:14 AM
jutn35's Avatar
G35 Coupe
I sure hope it goes away, and no more problems
i got a quote
$125.oo for 235-50zr-17 360 Treadwear -Falken ziex
Old Feb 27, 2009 | 05:20 PM
kalikiddo's Avatar
Same thing happen to my car with the donut...
I had to turn VDC off, cause your lil donut burns out and VDC will come on and try to keep you from losing control...Since you donut is much smaller and rotates more specially if you step on it to get back on the Freeway/Hwy.
Only explanation I thought of when it happend...
Got a new tire and everything runs ok and all lights went away.
Old Feb 27, 2009 | 11:55 PM
jutn35's Avatar
G35 Coupe
Thankyou as well for your input, Ya i remember gunning it a little ,and the car started to shake, so im guessing your explanation is same thing happend to me
Old Feb 28, 2009 | 08:20 AM
SVTCOBRA's Avatar
I keep a plugging kit and compressor in my trunk.
Plug the flat and patch it later. (assuming it is pluggable)
Old Mar 1, 2009 | 03:15 PM
jutn35's Avatar
G35 Coupe
Nope, i rode on it too long, and i shredded the inside, i got new tires yesterday, 2 for 300 - Falkens 235-50ZR-17, 360 tread wear at American Tire Depot
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
socaldavid
Sep 5, 2015 04:35 AM
Detailed Image
Sep 4, 2015 08:35 AM
