grinding noise
Old Mar 9, 2009 | 01:16 AM
blackgixer's Avatar
grinding noise
has anyone ever experience grinding noise?. as im crusing down the highway there is a grinding nosie when i turn the wheel to the right, but not the left. i wonder what it is.
Old Mar 9, 2009 | 06:31 PM
ttrank's Avatar
Grocery getter
How far to the right?
Are you lowered?
Old Mar 9, 2009 | 10:50 PM
Cobra911's Avatar
It will most likely be your wheel bearing, front one, but as to the left/right, you have to feel from which wheel it is coming from or let the mechanic test it, he should be able to determine which wheel it is.
Old Mar 10, 2009 | 12:09 AM
blackgixer's Avatar
yea im not lowered. stock everything. i was a little concern about the wheel bearing at first to. cause its comming from the right. as im tilting the steering wheel to the right.
Old Apr 3, 2009 | 07:48 AM
acemallone's Avatar
If you turn to the left and the grinding gets worse, most likely your passenger side wheel bearing. If it goes away when you turn right (takes the weight off of it) i'm almost 99% sure thats what it is. See if the sounds gets louder when you go fast..
Marlin84
Apr 1, 2020 12:52 PM
magnetism80
Feb 1, 2019 10:00 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
