A/C Question
Old Jul 1, 2004 | 07:37 PM
COMBUSTION's Avatar
A/C Question
What is the difference between auto A/C and econ A/C?
Old Jul 1, 2004 | 07:42 PM
Msedanman's Avatar
O.F. Administrator
Re: A/C Question
Econo-A/C helps reduce load to the engine thereby saving fuel. I've found it's effective in all but the hottest and most humid of days.
<font color=red>GSM</font color=red>
<font color=black>Silverstone Coupe</font color=black>
Old Jul 1, 2004 | 11:30 PM
Eddyhttp's Avatar
Re: A/C Question
hey this should help you a lot to understand really how it is used.
http://www.infinitihelp.com/Ownershi...y%20System.htm
What is the difference between "Auto" mode and "Econo" mode
AUTOMATIC OPERATION
Cooling and/ or dehumidified heating (AUTO) This mode may be normally used all year round as the system automatically works to keep a constant temperature. Air flow distribution and fan speed are also controlled automatically.
Push the AUTO button on. (AUTO will be displayed.)
Turn the temperature set dial to the left or right to set the desired temperature.
Adjust the temperature set dial to about 75° F (24° C) for normal operation.
The temperature of the passenger compartment will be maintained automatically. Air flow distribution and fan speed are also controlled automatically.
Heating (ECON)
The air conditioner does not activate. When you need to heat only, use this mode.
Push the ECON (Economy) button on. (ECON will be displayed.)
Do not set the temperature lower than the outside air temperature. Otherwise the system may not work properly.
Not recommended if windows fog up.
champppy
Mar 31, 2020 12:25 PM
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
baker2795
Sep 2, 2015 06:00 PM
INVADER_6MT
Sep 1, 2015 10:19 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
