need data system grill install info
Old Jul 2, 2004 | 09:20 PM
xenon's Avatar
I just painted and installed my grill. However it looks a bit weird. It looks as if my grill is sticking out a lotand that it doesnt look like its part of my car when looking at it profile. Can anyone tell me the correct way to install it?
Old Jul 2, 2004 | 09:52 PM
Kaneda's Avatar
Re: need data system grill install info
I had the same problem with mine. You can easily correct the alignment problem of the grill by using a high quality 3M double sided tape. You can easily find them at most Tap Plastic stores in your area.
I personally used 3M's water/weather proof double sided tape specifically designed for body kit taping. I've had mine on for a year, not a problem
Ken
Old Jul 2, 2004 | 09:55 PM
mattycNJ's Avatar
I did the same thing...
Old Jul 3, 2004 | 04:41 PM
xenon's Avatar
bump
Old Jul 3, 2004 | 05:02 PM
gte192t's Avatar
You were given a way to fix it, and it was used by another person. I don't think a bump is necessary
-Chris
Old Jul 4, 2004 | 01:50 AM
xenon's Avatar
bump. i want to find another way
Old Jul 4, 2004 | 11:23 AM
Roller_G's Avatar
There is a hole on the bottom of the grill. Get a screw, push the grill back the furthest you can to the frame and screw it down to the front bumper.
Works fine for me.
99 Supercharged PY Civic SI 13.8@101mph
03 BO G35 xx@xxmph...to be continued...
EnCr1pt3d
Jul 8, 2019 02:48 PM
miata007
Aug 17, 2015 04:36 PM
RA102223
Aug 15, 2015 09:24 PM
Team STILLEN
Aug 10, 2015 08:17 PM
joedaddy1
Jul 28, 2015 02:58 PM
