VSS module location?
Old Apr 28, 2009 | 04:45 PM
DenZeL KnighT's Avatar
Exclamation VSS module location?
Where is the VSS module location at? I don't need to know where the white/green wires at just need to know where the speed sensor is located directly at.
DenZeL KnighT
Old Apr 29, 2009 | 02:16 PM
giddyup69's Avatar
your question is too vague. there is no "speed sensor module" per se, that i know of. vss errors are usually calculated by the tcm or ecu via the can communication line from other sensors located on the car.... ie. wheel sensor, combination meter, vdc/tcs/abs control unit, etc...
maybe i'm just missing what you are saying. u should try posting this in the technical area of the forum... maybe someone more knowledgeable on the subject can help u out.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
ZoominG35
19 Inch
16
Oct 30, 2015 05:44 PM
ZoominG35
Audio/Video/Electronics
Oct 12, 2015 04:53 PM
Albanian122
NorthEast
Sep 28, 2015 03:03 PM
