03 vs 04... is there a big difference in "issues resolved"
Old Apr 30, 2009 | 08:07 PM
350zrunnin12s's Avatar
I am looking at a couple G's.. same mileage around 50k miles...
is there many more issues on an 03 vs an 04?
I know tire feathering perhaps was 1, as well as possible clutch issues (they are BOTH 6MTs)..
Should I shy away from 03s and only focus on 04s? I just dunno if they were all fixed in 04, or should I not even bother because both are the same.
Old Apr 30, 2009 | 08:59 PM
t7n7's Avatar
03-04 identical. 05 new interior trim 06-07 exterior changes + many new features.
as long as the car is driven properly and taken care of, all Gs are the same. Some people say the new REVUPS cause oil consumption, the 05s have bad transmissions (i dunno where they get this info), 03s are bad cuz they are the first model, 04 is good cuz its the next year (even though infiniti didn't make ANY changes)...
The window motor/bose headunit problem is on a few...
brembo brakes.... on m6 models...
and if you find an 04 for the same mileage as an 03, i would go with the 04
Old Apr 30, 2009 | 09:13 PM
SVTCOBRA's Avatar
Bought my 04 with 44K miles on it last summer.
No problems (knock knock). Tires are wearing fine.
Bought it cause I like the seats better in the 04 than in the 05 or 06 or 07.
Was ready to wait on a good, used G37 when I found out my butt loved the 04 seats!!!!
The dealership had just put on new Nissan pads. CRAPPY! I just replaced those dusty/squealing POS pads with Akebono ceramics (pro-act) and the squealing stopped as well as the dust storm.
Mine has the 05 AT shifter as opposed to the 03 AT shifter. Sometime in the 04's they changed from the button on the side to the button in front.
Good luck!!!
Old Apr 30, 2009 | 09:16 PM
G35fromPA's Avatar
04's seem to be a bit higher on the reliability ratings - a later model run is always a bit better if you can get it. Also, all 04's are pre-wired for satellite radio while not all 03's are, if you care.
Old Apr 30, 2009 | 09:23 PM
Thanks for the input so far .. I use to have an 04 350z enthusiast 6mt
I remember reading then or hearing that the 04s were "fixed". Nissan fixed the tire feathering issue on the 03s in 04.. and also the clutch was revised in 04..
That's why I was asking the question.
I really LOVE XM radio.. so I am bummed the 03 isn't prewired for it..
according to g35parts vin info and my 03 vin im looking at is older then those, and the current owner said it doesn't anyway =\
http://www.g35parts.com/9083/osc/pro...roducts_id=285
But if it's not pre-wired according to g35 parts, its $57 more... I dunno how hard it is to install or if I can buy the parts cheaper on ebay.
Does anyone have the model numbers for the xm stuff that came on 04+ ?
Old Apr 30, 2009 | 09:55 PM
cpufreak3's Avatar
Some 03's have satellite though, you just need to check.
Old Apr 30, 2009 | 10:10 PM
The car I am probably going to buy doesn't have it.
Old May 1, 2009 | 09:54 AM
t7n7's Avatar
check for the button near the FM/AM, CD buttons. If you see a "SAT" button, then its prewired
Old May 1, 2009 | 02:06 PM
Darqfallen's Avatar
Sat button is standard reguardless. My 03 has a "SAT" button but is not wired at all for satellite radio
Old May 1, 2009 | 02:35 PM
cpufreak3's Avatar
Wow, I didn't know that...
How can you tell if it's prewired? I assume if you press the switch, it should go to the Sat mode (but nothing will play w/o a subscription).
Old May 13, 2009 | 02:53 PM
Vinzo's Avatar
i got an 04 WOO
Old May 29, 2009 | 08:56 PM
Olezhka4's Avatar
I have an 03. Only a few problems, rear axle clicking and power door locks acting up.
Old May 30, 2009 | 01:31 AM
t7n7's Avatar
the factory unit sucks anyways.. and the 03-04 center console looks like ****... everytime i look at my center console, i feel a big urge to tear everything apart and change it around to something else...
my 03 is full of problems.. everyday someone is starring at it no matter where i drive.... hmmmm dunno when that will get fixed.
chinee
Jun 10, 2024 07:48 PM
Frankieg35
Mar 20, 2016 09:42 PM
Phenomenon9
Aug 9, 2015 01:34 AM
itschuckster
Jul 25, 2015 08:07 AM
