SLP, BRAKE and VCD off warning lights ???
Old Jun 1, 2009 | 08:03 AM
COMMANDOE's Avatar
Used 05 G35 29k miles have had for 1 month with flawless operation. I start it up this morning and I have on my dash warning lights. SLP, BRAKE, AND VCD OFF. I restarted car twice . Any ideas??? Car was recently inspected and as far as my brakes i was told my front pads were nearing need for replacement.
Apologize if in wrong area, but couldn't find anything in tech area.
thanks
Old Jun 1, 2009 | 09:22 AM
gary c's Avatar
I'd begin by releasing the brake and turning the VCD back on....logically that should clear you're warning lights.
Gary
Old Jun 1, 2009 | 09:35 AM
COMMANDOE's Avatar
Um Geez Gary didn't think of that ... ROFL....... Come on Gary give me a little credit there I'm not george Bush. First thing i did but thanks
Old Jun 1, 2009 | 09:55 AM
gary c's Avatar
HAHA....hey ya gotta start somewhere. Alright, phase two check the fuses that apply to the dash. You should find one that's toast/burnt. Sounds like a broken circuit....fuse! If that doesn't work take your G to a Nissan dealership, not Infiniti cause they charge 50% more just because they can.... Post the results of your findings and G/L!
Gary
Old Jun 1, 2009 | 11:25 AM
pwebb's Avatar
brake fluid level. you need brakes.
/end.
Old Jun 1, 2009 | 11:27 AM
COMMANDOE's Avatar
It was merely brake fluid. WHEW!!! Thanks for suggestions all. Problema solved for 6 bucks!
Old Jun 1, 2009 | 07:32 PM
gary c's Avatar
That's weird, but all those lights were brake related....forget logic it doesn't work either....
Gary
Old Jun 1, 2009 | 07:35 PM
eljoker's Avatar
gary the VET for the win!!!!
Old Jun 1, 2009 | 07:37 PM
COMMANDOE's Avatar
Yeah and it wasn't even below minimum. Slightly less than half way between max and minimum. Figure that? Knowlege is POWER!. I was going to drive to my closest Infiniti dealer which is 60 miles.
Old Aug 20, 2012 | 04:24 PM
jaythree's Avatar
My fluid levels are good but my slp keeps engaging. Is there a way to disconnect it all together
Old Aug 24, 2012 | 07:33 PM
6mtg's Avatar
may be a bad wheel speed sensor
Old Aug 24, 2012 | 10:24 PM
jaythree's Avatar
ill check into it, thank you
Lsantana757
Jul 20, 2015 09:08 AM
mjfenix
Jul 17, 2015 02:07 PM
