Need Help ASAP, (g37 wheels,lug spacer)
Old Jul 13, 2009 | 03:25 PM
randy021186's Avatar
well i was at the dealer today to get my car fix, the mechanic told me that the lugs i have on the car is not holding the wheel properly .....
i have installed the 19" g37 rims and i need to know what size lug to use and what size spacer? i want the lug to have the chrome finish and not the bolt kind!.....
and should i use g35 alignment or g37 alignment specs?
btw i was getting a new radio, control rod, heater switch, tie rod, thats gonna be a crazy warranty bill.
Old Jul 13, 2009 | 04:28 PM
9600baud's Avatar
are you using aftermarket lugs? Most aftermarket lugs are tapered (flat) and OEM wheels are acorn (round) thats why they arent compatible.
Old Jul 13, 2009 | 05:56 PM
STCLAIRWEST's Avatar
I wouldnt be driving too much around until i get new lugs if i was you.
Old Jul 14, 2009 | 12:39 PM
LightsOut's Avatar
SIETESG
well if I had G37 wheels ill put on 255/35 and 275/35 tires with 25mm spacer front and 30mm spacer rear.
as for alignment, just align the wheels to best camber for your vehicle.
tphan
Aug 31, 2015 10:45 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
