Tranny Question 6MT - Help
Old Jul 25, 2004 | 05:42 PM
luv2drive's Avatar
20 Year Member
Guys,
I have 04 6MT... When I pulled it into garage and had windows open I noticed that when I let clutch out (out of gear of course) I hear a kinda gear meshing noise. When I put clutch in it goes away. I know you should hear some noise difference but was wonder how much noise is normal. I guess I never noticed it much cause usually I have the windows up cause Air was on.
Also do any of you get a noise when shutting off engine (rattle noise / marbles) for a about a second if you turn off car with clutch in.
Thanks in advance.
Old Jul 25, 2004 | 05:54 PM
Brando's Avatar
Re: Tranny Question 6MT - Help
It is the throw out bearings in the clutch .....most G's rattle like hell......mine do.
"I like you.....You remind me of myself when I was young and foolish"
Old Jul 25, 2004 | 05:59 PM
DragonGcoupe's Avatar
Ditto.
Black / Black 2004 GcoupeMT. Premium. Splash Guardz.
Old Jul 25, 2004 | 07:30 PM
lowrider's Avatar
When you park the car, you really should leave it in gear (either first or reverse), as well as use the parking brake. I know many of you don't do this, but leaving it in gear, whether on a hill or on the flat, is like leaving an automatic transmission in park. You immobilize (lock) the rear wheels.
Lou
Old Jul 26, 2004 | 08:07 AM
XCELR8's Avatar
Same here mine makes noise like crazy
2003 BLK/BLK 6MT Injen, clear corners, Eibach sways and springs, tint
My G on a photo shoot. More to come!
Old Jul 26, 2004 | 12:04 PM
zazaracing's Avatar
Team Transport Member
Shoulds like the usual chatter box!
Anyone know if this sound will go away if you change the clutch to like the nismo one or whatever?
03 6MT Coupe Blk/Blk> Injen CAI, Hotchkis adj Sway Bars, Test Pipes< "Nt G R8D" Aj
Old Jul 27, 2004 | 03:40 PM
kel's Avatar
kel
thought i was the only one with this problem. went to the dealer like four times, they kept saying everything was fine but, by 5th they realized that there was a problem and now im getting a new tranny and clucth for free
Old Jul 27, 2004 | 06:55 PM
zazaracing's Avatar
LOL lucky guy but more than likely its going to have the same noise
Old Jul 28, 2004 | 02:41 AM
metasystem's Avatar
04 G35 Coupe 6MT Gold Brembo’s
Quote: ***Anyone know if this sound will go away if you change the clutch to like the nismo one or whatever?***
An aftermarket performance clutch like the Nismo, JIC or Exedy will be noisier than the oem clutch. I have an Exedy carbon racing clutch/ pressure plate and flywheel, and it's definitely noisier than stock, but it performs better and can handle much more hp/ torque.
Old Jul 28, 2004 | 09:01 AM
BlckMgk's Avatar
Ahh I just posted this question in the Tech forum, I guess this is the same thing I'm hearing.
So this noise is just something we have to "deal" with, or is generaly accepted?
Hmm...
-BM
Old Jul 28, 2004 | 09:18 AM
luv2drive's Avatar
20 Year Member
It would seem many of us have the same issue. I have a new 04. Went to dealer last night and started up another 6MT 04 (had 1 mile on it) and guess what... same noise when turning off with clutch out and also same noise when at idle in neutral with clutch out. I am guessing now this is normal noise and gets somewhat louder as car breaks in. Does anyone know if it is the throw out bearing this is noisey or the gears in tranny? Will noise get less as time goes on or worse?
Old Jul 28, 2004 | 03:49 PM
Growler's Avatar
We have very vocal clutch bearings and tranny components. My tranny and clutch are loud in a closed garage space, and sure, when you disengage the clutch the noise is reduced considerably. Never had a problem after a year and a half the noise has not gotten any worse. You can actually hear the enagement position of the clutch when you enagage or disengage even in neutral.
Old Jul 28, 2004 | 04:37 PM
luv2drive's Avatar
20 Year Member
Many thanks to all for input.... I called consumer affairs which then got a call from a "manager" from consumer affairs who actually owned a 03 6MT and has the same noises from tranny/clutch!!!! He called some "technical" people he knew and they confirmed that noise is totally normal and you will hear it more in enclosed enviorment. Noise should not get any louder over years of driving. They said that due to the high level of performance parts and engr the tranny makes this noise. They know about it and they said it is perffectly normal. Same on 350Z. They said with Air off and radio off you can hear it in car somewhat. They said no plans to change tranny to make it quieter. Performance vs. quiet... I dunno which is better... i tend to lean for performance since I bought a performance car.... but that said I don't want it to loud.
Th611
Oct 27, 2015 03:48 PM
RA081024
Aug 18, 2015 07:03 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
nervseele
Jul 17, 2015 11:21 PM
