Rattling when in neutral??
Old Jul 25, 2009 | 09:23 AM
jwolfpk's Avatar
Hey guys I'm experiencing a rattle when my car is in neutral but that rattle goes away as soon as i push the clutch pedal in.. Can this be a throw out bearing???anybody experience this before?
Old Jul 25, 2009 | 10:06 AM
jwolfpk's Avatar
anyone??
Old Jul 25, 2009 | 12:56 PM
wise-1's Avatar
I believe it is the throw-out bearings. These cars have a tendency for it. Give the search tool a try and you will see a few more extensive threads about it.
Old Jul 25, 2009 | 12:58 PM
nghiars's Avatar
sounds like the normal clutch and flywheel chatter
Old Jul 25, 2009 | 01:53 PM
jwolfpk's Avatar
the clutch is like brand new so i dont think its that
Old Jul 25, 2009 | 06:27 PM
NoHomo's Avatar
If you got a brand new clutch chances are it comes with a new throwout bearing... Unless you didn't buy a complete kit, What's the full details on the clutch and did you install it yourself???
Old Jul 25, 2009 | 07:26 PM
jwolfpk's Avatar
the clutch nd flywheel were replaced by Infiniti at the end of last summer..
Old Jul 25, 2009 | 07:33 PM
dofu's Avatar
20 Year Member
Is it factory clutch and flywheel or aftermarket? After you swap out the original clutch and flywheel, your clutch will never be the same again. I'm betting it's most likely just chatter, although it might be the bearing too.
Bring it back to them and see what they say...
Old Jul 26, 2009 | 10:39 AM
jwolfpk's Avatar
yeah they replaced it with the factory clutch and flywheel cost $2,200 im thinking i should have went with an aftermarket.
Old Jul 26, 2009 | 11:03 AM
gary c's Avatar
Without a doubt, what you're hearing is the throwout bearing. That should have been replaced when the new clutch was installed, regardless of how good it looked! That would be like taking a shower and putting your old shorts back on....
Gary
Old Jul 26, 2009 | 12:51 PM
jwolfpk's Avatar
soo you think that i should take it to infiniti nd they should fix it even though im out of warranty??cuz that was supposed to be changed as well right?
Old Jul 26, 2009 | 03:59 PM
dofu's Avatar
20 Year Member
Gary
These throwout bearings have a tendency to go out fast. Even if they replaced it with a new one when they changed the clutch, it's been almost a year, which seems to be enough time for a new throwout bearing to go bad, depending on how many miles have been put on the car since then. But from what I remember, the sound isn't that bad of a sign... Even though the throwout bearing is making sounds, you should be fine. When it actually goes out, you'll know.
But I wouldn't see the harm in going back to see what they say, whether they'll be charging you or not.
Old Jul 26, 2009 | 04:07 PM
jwolfpk's Avatar
thanks for all your help!!
Old Jul 27, 2009 | 07:19 PM
Curt G's Avatar
+1
Try a search, you will find that many people with stock clutch have this "cement mixer" sound, which seems to be normal for these cars. This is completely different from "chatter" which is what happens when you're engaging the clutch and the car, well, chatters.
Old Jul 27, 2009 | 10:08 PM
jwolfpk's Avatar
thanks again guys..Do you guys know if Infiniti will adjust the engagement point on my clutch for free because that is starting to annoy me as well??
