18 inch coupe wheel question?
I wanted to know if these wheels are all the same size??? Fronts and rear rims the same size? I know the tires are different, but wanted to make sure the wheels are the same??
I have a buddy with a 350Z with the 18 inchers on and swears he has three rear wheels and one front???
thanks for the info...
yes the rims are the same size, the only difference is that the fronts have a hole in them for the bolt that is on the rotor hat, so that you can only put the front wheels on the front. remove the bolt and you can mount the rear rims on the front.
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
