fuel Tank issues and dealer headaches..input please
Old Sep 7, 2009 | 07:15 PM
randy021186's Avatar
update...well they gave me the car back and replace the sending unti to the guage this time and something else,..............SAME PROBLEM can't fill more than half way.....this time i am going to be furious when i go back there!...
Old Sep 18, 2009 | 04:08 PM
badassflip's Avatar
yo guys, same problem here. I can't fill over 8 gallons !!!!!!!!!! and im out of warrenty too!
Old Sep 19, 2009 | 12:25 AM
silvsurf's Avatar
Same problem with mine...also out of warranty.
Old Sep 19, 2009 | 07:55 PM
the_sedan's Avatar
uhh a filler neck tube is not gonna fix the problem. there are 2 fixes to this problem. which my 04 brembo coupe does after about 10 gallons. there is an updated cut-off valve that is on the inside of the tank from the filler tube, and an updated bracket that also goes on the inside of the tank on another valve in the middle of the tank. this is common on Gs and Ms. i know....imma infiniti tech.
Old Sep 19, 2009 | 10:02 PM
V35 Skyline GT's Avatar
6MT Coupe
Yeah the TSB on this looks quite involved and a pain to do.
Old Sep 19, 2009 | 10:17 PM
the_sedan's Avatar
its not all that bad actually. maybe its just easier to me since ive done them before. i could have them both put in in like 15 min and most of the time is takin the seat and fuel pump out. lol the coupes...ill admit....do make the job a bitch since you cant lay directly on top of the tank *no back doors * cuz ur gonna be up to ur elbow in that gas tank. just make sure u have 1/8 tank or less if/when u do it.
Old Sep 20, 2009 | 12:52 PM
Mark_V35's Avatar
same problem happened to me as well when i decided to have a peak inside my fuel tank to see if the thing was clean inside after 50,000 kms
when i put the fuel pump back in, i put it back in the wrong way. there is a wire which runs around the fuel pump if i remember it goes around it clockwise, and i put it back in anti-clockwise. this then blocked off some hose which sends the correct reading to the fuel sender. i only got 1/2 tank full on the gauge when i filled up the whole tank.
now interesting enough, i fixed the problem by just putting it back in the right way. had to replace the o-ring because it swelled up after fuel got onto it. whats more interesting, is that i used to never be able to full up my car past the F but now it goes past the F like a normal car would. happy i managed to kill 2 birds with 1 stone for some reason!
Old Sep 20, 2009 | 02:53 PM
the_sedan's Avatar
the fuel pump has notches that fit for the bolt holes...just make sure it goes back in with that hose towards the rear like it came off and the ring fits on it since it has flat spots on the sides....pretty straight forward.
Old Oct 2, 2009 | 03:20 PM
well just to give you guys an update the problem is still there and i am going back for the 6 the time!!! i hope you are right "the_coupe"...i will actually print this and show it to them
Old Oct 3, 2009 | 01:53 AM
emorehs's Avatar
Ok now that a lot of people complain about this issue I will tell mine (not to jack your thread bro.) I always fill my Gas in "Shell" since i got the car (w/ no problem) when I traveled to SD I have to filled my gas to "chevron" about quarter empty( it only fill me to half and stop won't fill anymore). I ignore it because I always go to "shell with no problem. Yesterday 10/01/09 I filled my gas coz i ran out I went to "76" and it only gave me 11 gal. so what i did Just run to the nearest shell and filled my gas.. My point is why I don't have problem filling my tank with shell.. "weird i should say."
Old Oct 3, 2009 | 03:45 AM
iamchris's Avatar
Originally Posted by texasg
my car is in there for the same reason. i swear they looked at me funny when i told them i wasnt able to fill up all the way l guess they never heard of the issue. my car would fill up with 14 gals when i 1st got the car it would fill up with 17
wait what? how many gallons does the 04 coupe hold?
Old Oct 3, 2009 | 11:02 AM
GoDaddy's Avatar
I got a similar issue, now i'm afraid to take it to the dealer and I don't have warranty..
If I go to the dealer, and they didn't fix the issue after the first time and they say it's another unit that they must change are they suppose to charge you for the new component ???
After 5-6 try I hope they don't charge you all those components since it's their mistake for now fixing the issue at the first place. Or I'm just wrong ...
Old Oct 30, 2009 | 05:32 PM
DAMMMMMMM ROUND 7....
they replace sending unit twice, fuel pump and other ****!!!!....anyways they suggest replacing the cluster...because there is a short.. ...and i printed this thread and showed the MASTER TECH ...don't know what else i can do
Old Nov 16, 2009 | 12:17 PM
  #30
well is it fixed, Fuel tank replacement
