Need help deciding on lowering springs
Old Aug 17, 2009 | 05:14 PM
sofreshh's Avatar
ok well im trying to decide which springs i should get for my g35 coupe with oem 18's.
I narrowed down my suggestions and im trying to decide on whether to get:
Eibach sportline springs
tein s-tech springs
350z tein s-tech springs
I want to know which choice will be the best for looks, performance, and ride comfort. Also, i wanted to know if i would need a camber kit or if i would need a realignment. Thanks
Old Aug 17, 2009 | 05:53 PM
code2424's Avatar
for ride comfort your gonna need like coilovers.
Old Aug 17, 2009 | 06:42 PM
Drowe303's Avatar
Camber kit is recommended for all 3 of those. Im pretty sure the eibach sportlines would put you the lowest. But most people on here go with the s-techs, either 350z or g35. The 350z s-techs would put you lower out of the two. If you go with the sportlines make sure you pick up some tokico d-spec shocks. Idk how well the stock struts would handle with those springs.
Old Aug 17, 2009 | 08:16 PM
gary c's Avatar
Welcome to Driver Sofreshhhhh....=)
tein s-tech springs
One thing to keep in mind, no matter how you lower your car you're going to need adjustable a-arms and rear toe adjusters. Using any of the springs listed above you'll also need aftermarket shocks, the OEM shocks will soon fail. By doing a search under company's like Tein you'll be able to see just how low the S-Techs will lower your car, I believe it's 1" to 1.5" for those. My Tein H-Techs ride like OEM and I have all the suspension adjusters and adjustable Bilstein shocks, I'm lowered just under an inch. After completing this mod you'll NEED to have a 4 wheel alignment....
Gary
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
StreetStandard
Suspension-Vendor
Jan 18, 2016 03:36 PM
nosam1g
Aug 22, 2015 11:58 PM
andresito7
Aug 1, 2015 04:53 AM
itschuckster
Jul 25, 2015 08:07 AM
