SHIFTER VIBRATION
Old Aug 18, 2004 | 03:33 PM
pjsg35's Avatar
SHIFTER VIBRATION
On my way home from work yesterday I was in fourth doing about 60/65 and I notice the shifter vibrating violently (a lot more then what im used to) I then went up to fifth and then sixth, and the shaking toned down to (respectable level) what im used to. At the same time I felt that my front wheels were also vibrating/shaking. I pulled over and didnt notice anything unusual. On my way to work this morning I tried to duplicate the problem.......and nothing at all. Could one of my rims be off balance/bent or is this a tranny issue? Either way I have a service appt. for tomorrow...I need new pads at 11K??...and ill see if they can come up with something. Thanks PJ
04 6MT/DG/G/PRE/AERO/19*8-19*10 iFORGE AEROS
Old Aug 18, 2004 | 04:57 PM
Memphis's Avatar
Re: SHIFTER VIBRATION
Did you take the same route (same direction on the road)today as when you had the severe vibration? Also, did you go the same speed. A bent wheel or a lost wheel weight will be a balance issue and it can be speed specific.
It doesn't sound like a transmission issue. To me, it sounds like it was a road surface issue because if you went through the gears and thus went the same speeds today, a wheel balance issue would have occurred again.
Memphis
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
5150DS
Sep 26, 2015 07:47 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
