tpms problem.
Old Nov 6, 2009 | 03:43 PM
loki05's Avatar
tpms problem.
So last week my tpms came and I went to a local gas station to check all the air pressures.
One of the tire was really low on air so I filled it back up to 34 psi.
Today, a week later, the light came on again and I went to a shop to get the tires checked for nails or any holes and they said there were none and just tightened the valves more.
I did upgrade my front tires from 225-40-19 to 245-35-19
and I'm running stock rear tires 245-40-19.
I've been running this setup for about a month and never had a problem with the tpms or anything until now...
Could this be the problem?
Old Nov 6, 2009 | 06:18 PM
elperuano's Avatar
I would say most likely but not sure. They were set for ur original stock tires so the change might throw em off. I switched from stock to aftermarket Work Wheels n my tpms is always on.
Old Nov 20, 2009 | 11:05 PM
Bruin003's Avatar
did you try doing the reset procedure?
Old Nov 24, 2009 | 04:11 PM
gsoto999's Avatar
Try resetting your ECU, it worked for me!!!
SKUNK2 5/8 FTW!!!!
AL8782
Oct 3, 2015 10:26 AM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
bananax
Wheels & Tires CDN
Sep 10, 2015 06:14 PM
