New drive belts make horrible squealing sound
Old Nov 18, 2009 | 03:08 PM
scottfedm's Avatar
you gotta get under your car take off the plastic sheild and there are 2 12mm bolts....one on each tesioner pulley (one on the right and one on the left. They are the easiest bolts to get to under there. But before you can loosen them you need to loosen the pulles first by lossening the bolt on the front to the tensioner pulley. It will take you 3 minutes onse you drop the sheild.
Old Nov 18, 2009 | 04:49 PM
skddmorse's Avatar
New belts can squeak and some that is by design. I used to be a quality manager for the Gates corporation who supplies belts to every quto shop except autozone. My opinion, buy belts from any store except autozone.
Napa would be my choice you can buy a Gates brand or Napa,they are made in the same factory on the same line in Jefferson NC.... We also made a blue racing belt for the 350z or G35. Look for it...
Edit: Never buy Dayco or the belt with horizontal ribs. The ribs should only be vertical around the inside of the belt. The horizontal ribs are put there to make noise at a lower milage....
Old Nov 18, 2009 | 05:59 PM
partyman66's Avatar
Sometimes you need to retighten new belts a week or so after putting them in. They often stretch a tad at first when installed, much like a new drive chain on a dirtbike or motorcycle.
Old Nov 20, 2009 | 11:23 PM
Bruin003's Avatar
you just gotta tighten them up a little bit more...this is very common after you replace belts
Old Nov 30, 2009 | 02:42 AM
lionhb26's Avatar
dude i have personally talked to an infiniti mechanic about this cuz i replaced mine with the advance auto parts brand and got some squealing... he told me to tighten them, i did, no squeal... the 'only OEM' stuff is not necessarily true... at least in my experience
Old Nov 30, 2009 | 02:01 PM
smokincoupe's Avatar
sometimes people put them on backwards
Old Nov 30, 2009 | 02:09 PM
scrapiron7's Avatar
Mine squeeled using OEM Infiniti belts within 2 days of replacing them. I had to retighten them. I'm sure this is the case with any belt, OEM or not.
Old Dec 2, 2009 | 12:28 AM
paymon's Avatar
Well I tightened my autozone belts, and they squealed even more. I give up. I am going to the nissan dealer and having them install new OEM belts
Old Dec 2, 2009 | 01:43 AM
TIAN's Avatar
Hold The Line
I just installed gatorbacks and I got the squeal
Old Dec 2, 2009 | 05:57 AM
Blue Dream's Avatar
I drove ttrank's car solo
A friend and I replaced our belts with OEM a couple of weeks ago and no squealing so far.
Old Dec 3, 2009 | 06:42 PM
paymon's Avatar
Update: i replaced the ****ty duralast belts with new OEM belts and there is no more noise. Just the feel of the difference between the belts is incredible. Never again will I buy duralast anything
Old Dec 3, 2009 | 07:24 PM
umair's Avatar
ill do you one better... NEVER buy from Autozone!!!
Old Dec 4, 2009 | 01:48 AM
TIAN's Avatar
Hold The Line
I bought my gatorbacks from autozone As far as I'm concerned its a matter of tightening or loosening the belt
Old Dec 4, 2009 | 03:45 PM
bocatrip's Avatar
Just did my belts with OEM. No squeaks or squeals. For the minimum cost difference, OEM is the way to go.
Old Dec 7, 2009 | 01:53 AM
  #30
LRg626's Avatar
tighten it up
