Oil Consumption for Dummies?
Old Nov 23, 2009 | 01:21 PM
WalksInDarkness's Avatar
Question Oil Consumption for Dummies?
I had a vague knowledge of the "Oil Consumption" problem before I bought my '03 G35c, but didn't realize it was so widespread. Since I have only put on <500 miles, I haven't even checked the oil (had it changed the first day anyhow).
Is there a FAQ on here, describing the problem?
If not, can someone post the key points?
Thanks in advance!
Old Nov 27, 2009 | 09:30 PM
ceeze's Avatar
From what i understand, the oil consumption problem is only prevalent on manual models which have a higher rpm line which does something to the seals.
Apparently, automatics are in the clear. You should be fine. Just check oil regularly.
Old Nov 28, 2009 | 05:38 AM
Ditchdrinker's Avatar
From what I understand, The oil consumption problem is a bug in a few 05-06 G35 sedans and 05-07 G35 coupes. The problem is more common manual transmissions, but has been found in a small amount of cars with automatic transmissions.
As for a FAQ, https://g35driver.com/forums/tsb-tec...ption-tsb.html
f22raptor
Mar 18, 2016 08:50 AM
prinny
Nov 22, 2015 11:07 PM
mbe32
Nov 13, 2015 11:09 PM
9tray turbo
Sep 29, 2015 10:22 PM
