Driver's Seat Swap (for a sedan seat?)
Old Nov 25, 2009 | 07:23 PM
H.A.W.'s Avatar
Does anyone know if a G35 sedan seat will fit into a 2003 G35 coupe? I would like to know if the wiring harnesses are the same and if the sedan seat is slim enough (or too wide) to fit into the coupe. I asked the dealership and they only knew that the seat tracks are different, but they were not sure about the wiring harness and width. (A local car upholstery shop said that if the seat is slim enough and the wiring harness is the same, they could modify the tracks.) My reason for changing the seat is because it has too much bolstering for my size (6’3”/230 lbs); the sedan’s seat seems much more comfortable as they have significantly less pronounced bolsters.
Old Dec 31, 2009 | 07:09 AM
orionthx's Avatar
+1 bump
Old Mar 14, 2010 | 09:59 AM
nadeem132's Avatar
also will the coupe rear seat fit my sedan
Old Mar 14, 2010 | 10:25 AM
Swivel's Avatar
Moderator
People have swapped coupe seats into a sedan so I presume it'll work in the other direction, there are several threads on it, search them up. If you are close, I'd happily swap with you.
Old Mar 14, 2010 | 10:29 AM
nadeem132's Avatar
im in ny but i been searchin all day really didnt find much i need my rear seats flip down cuz i have a custom built box for spl so i hope this will work how hard is it to do
Old Mar 14, 2010 | 10:36 AM
Swivel's Avatar
Moderator
I don't think rears are swappable, I was referring to fronts only, sorry.
Old Mar 15, 2010 | 12:44 AM
djjg35's Avatar
only the front you can swap
si_driver
Interior
Jul 25, 2015 09:22 AM
HypedAndy
Southern California
Jul 21, 2015 03:46 PM
whattf
Drivetrain
Jul 20, 2015 11:19 AM
realtalk21
Jul 20, 2015 09:07 AM
brian_z
Jul 20, 2015 01:30 AM
