heated seat switch light out
i did a search for what type of light to get to replace my burnt out heated seat switch light. i found this post from a while back.
https://g35driver.com/forums/g35-sed...-mod-pics.html
so i went to the website to look at purchasing some LEDs and modding it like the OP of that post did. i went to checkout and noticed that the lock on the bottom corner of my browser had an exclamation point on it. so i stopped from proceeding. my question to you guys is do you know where i can get these LEDs the OP was talking about from somewhere else? i really want to change it out asap and my driver's side window light is out too. thanks.
http://www.autolumination.com/
I have ordered from here.. Good service.
Let me know what you find. Mine are both out.. LOL
The one for the clock is
Item Name: Neowedge
Item Options: Color: Super White
Lens: Type B Led
Item Number: Single Led
Item Name: Neowedge
Lens: Type B Led
heated seats
so to get this straight...Ur lights frm ur heated seat thing are not on regardless if ur using it or not??? If so, how would u fix that because my driver side is like that and Im a pretty picky person..hehehe thanks I know its a lil late but I just say it again
Thanks
Thanks
I don't mean to bring a thread back from the dead, but how do you replace the bulb for the driver's side switch? Do you have to rip the whole console apart?
you have to take apart the center console where the shifter is. not too bad to get to. i removed my dead bulb but realized i needed a 3mm LED to replace it. i have to order some LED's.
apparently infiniti doesn't sell just a bulb for that from what i've read in the threads. they want to sell u a whole new switch. i'm getting some LEDs off of ebay. look up this user, jeledhk. check out their store. they have a crap load of LEDs. like i said earlier, they are 3mm LEDs. and since i'm modding my car to do half amber half white, i'm getting some white one to light up the seat icon, and keeping the amber when it's turned on.
just put the white LED's in. they are freagin too bright. took me a while to figure out that i had to use the supplied resistors. i burnt through a few LED's. but at least it's done. so glad that project is over but wished i would have gotten less brighter LED's now. oh well.
to anyone who will use the vendor i did off of ebay, go with the 12000 mcd brightness. not the 22000 mcd one that i used.
Specifications
I have the specs for the grain of wheat which are used in the Clock: 12VDC-75mA and I believe they are 5mm... Make sure you don't go past the 75mA because I had one that was higher and my clock bulb started to smoke. Not good haha. I quickly disconnected and realized that the 12V wasn't the issue and no harm was done.
Micale757
Lighting
Apr 8, 2020 10:46 AM
vstypicals
Jul 20, 2015 10:55 PM
