Overfilled oil by 1/2 a cm okay to drive or no?
Old Dec 9, 2009 | 07:05 PM
jibberjabbers's Avatar
Can't seem to find a jack point on the car. I need to drive it up a ramp to pour out some oil.
Okay to drive?
Old Dec 9, 2009 | 07:09 PM
caketech's Avatar
i would say it's okay.
but when'd you check it? for the mechanically uninclined, you should be careful checking the oil in the VQ35's
i hate checking the oil in our cars, you have to wait for it to settle for quite a while.
Old Dec 9, 2009 | 07:11 PM
Iamnotkento's Avatar
Why worry bout something ****ing up, when you can just simply crawl under the car and unscrew one bolt and fix the problem?
Old Dec 9, 2009 | 07:20 PM
Dude, theres 24 bolts and an underbody cover I have to get to before I can unscrew 1 oil bolt.
I need to find a jack point real quick.
Old Dec 9, 2009 | 07:25 PM
spinna001's Avatar
dude you do not have to take down all the bolts
Old Dec 9, 2009 | 07:32 PM
thescreensavers's Avatar
Mr.202?
http://www.infinitihelp.com/diy/gcou..._procedure.htm
Old Dec 9, 2009 | 07:49 PM
It's actually overfilled by 1 inch. I think imma hit up someone to go to kragen real quick to pick up a siphon pump.
Old Dec 9, 2009 | 08:52 PM
Ok. I forgot you had to take 24 bolts off just to change the oil.
Just pour some water into your engine, around 16o.z and the oil will pour out of the engine. Around 1inch, where you want your oil to be right. Don't worry about the water in your engine, it will evaporate when you drive it for a while.
GOOD LUCK.
Old Dec 9, 2009 | 09:08 PM
you serious with the water comment? cmon now...
I just did it the ghetto way. Long plastic aquarium tube and a syringe.
Old Dec 14, 2009 | 04:15 AM
Footballmania32's Avatar
Just pour some water into your engine...
wow.....
Old Dec 14, 2009 | 12:24 PM
Deepdiver's Avatar
Originally Posted by iamnotkento
ok. I forgot you had to take 24 bolts off just to change the oil.
Good luck.
Old Dec 14, 2009 | 03:33 PM
CLEANBS's Avatar
+1 on pouring water in
Cheap diy for a engine flush
Old Dec 14, 2009 | 03:38 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
Any further BS comments will not be tolerated.
Old Dec 14, 2009 | 03:43 PM
Jeff92se's Avatar
Red Card Crew
I'm surprised no one has asked how much he actually poured in considering how insanely idiotic our stock dipstick is.
Old Dec 14, 2009 | 03:47 PM
Swivel's Avatar
Moderator
I'm not big on Brilliant Silver, either.
Sounds like OP got it handled.
So how much DID you put in?
