Leaking Diff & Dash Lights
My '03 G35 coupe w/ 75k miles recently flashed the Slip, VDC, and brake dash lights. They went away the same day, but are now back. I stuck my head under the car and there is a dark fluid slowly leaking down from the top of the diff. I haven't had time to jack it up yet and confirm.
Is there anything else above the diff that could be leaking? Or is it likely the diff?
Thank you.
Thank you.
When was the last time you change the diff Fluid?
It's suppose to be changed every 30K
Also it might be your diff bushing
G35/350z have been know for the diff bushing blowing out and that can also be
the dark stains you are seeing
poktanG35
Engine - Exhaust
Oct 26, 2015 03:32 AM
