2003 auto to 2007 G35S differential swap ?
Old Dec 17, 2009 | 01:20 PM
SyCo's Avatar
DIY 03 G35 Coupe 5AT to 07 G35S 5AT differential swap !!
I've found a used differential (complete pumpkin) from a 2007 G35 S auto with 3.7 FD. So I've searched a lot but I did not find a 100% positive answer yet.
I have a 2003 Coupe 5AT with the 3.3 VLSD differential. I know that the 6MT have 3.5 differential and a different pumpkin because of gear size inside. I know I can swap a complete 6MT pumpkin without problem (except for the cruise control).
I've also found that if I had a 6MT pumpkin I could have swapped the gears from a 2007 G35S without problem.
Now, since I'm auto, can I swap the complete 2007 pumpkin into the bac of my 2003 ??
Some says yes but without proofs and some only talks about gears swap
EDIT: Maybe also confirm that the 2007 drive axles would fit on my 2003 ??
EDIT2: See below IT WORKS !!!
Thanks a lot for your help
Old Dec 17, 2009 | 01:58 PM
SyCo's Avatar
this thread seems to confirm it will fit -> 2007 350z 3.69 differential applicability
and precisely this post
Originally Posted by Tollboothwilley
Z/G pumpkins are all interchangeable so far.
The gear ratios are (approx) 3.3 for 5AT, 3.5 for MT and 07(Z)/08(G) are 3.7
So if someone already did it or can confirm ?
Old Dec 18, 2009 | 01:06 AM
Tollboothwilley's Avatar
I was wrong...the 350Z (2007) doesn't have the 3.69 it has the 3.53
the 2007 G35 AUTO does have the 3.69 though
nobody knows if it will interchange yet
where did you find the diff?
I want to at least try the swap...see if it is a direct swap
Old Dec 18, 2009 | 07:56 AM
SyCo's Avatar
no problem for the Z info because it's from a 2007 G35 S...
Found it in a local ad from a salvaged G35 S. I'm still dealing for a price but I will most probably buy it and try it. If it doesn't fit I saw another ad for a 2003 6MT diff real cheap that I can use for the pumpkin. I'm still awaiting news from the seller.
thanks
Old Jan 3, 2010 | 12:38 PM
SyCo's Avatar
success !! See here --> DIY 03 to 07 pumpkin swap
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
HypedAndy
Southern California
Jul 21, 2015 03:46 PM
realtalk21
Jul 20, 2015 09:07 AM
