Projector cutoff problem?
Old May 17, 2010 | 09:50 AM
bina12834's Avatar
i had the dealer check out the flare problem last time i was in for an oil change. He said that the flair was normal and that it was just the light reflecting off the reflectors inside the headlight. in my head i was like there arent any reflectors outside of the projector in the headlight assembly. He said they compared it to another G35 they had in the shop and it had the same flare. Can anyone else check their headlights and see if they have the flare too??
Old May 17, 2010 | 03:56 PM
parhamm1's Avatar
I'll do it tonight if you PM me to remind me...
Old May 17, 2010 | 03:59 PM
bina12834's Avatar
thanks! ill PM you a little later tonight.
Old May 17, 2010 | 07:20 PM
Christian421's Avatar
I believe that it is normal, and the difference is mean't to not blind on coming traffic. Raising and lowering your headlights is as simple as turning a screw under the hood. Anyone who has done this will tell you that both headlights move up and down together rather than individually.
Here's the DIY for adjusting your headlights.
https://g35driver.com/forums/body-in...rojectors.html
Old May 19, 2010 | 09:14 AM
bina12834's Avatar
i forgot to PM you to remind you...lol...hopefully ill remember tonight.
Freeman186
Sep 6, 2023 10:07 AM
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
Jnm07
Sep 5, 2015 01:16 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
kevintandmd
Sep 3, 2015 06:41 PM
