clutch help needed
Old Jan 5, 2010 | 03:54 AM
furry35's Avatar
clutch help needed
I have a 03 g35 6mt. it has about 70k on it and i am the 2nd owner. my clutch just went out today while i was on my way to work, so i literally had to force the gears in to make it to my friends house which was on the way. later i went to a mechanic and he said it was mostly likely the clutch had to be replaced and he got help from a transmission shop next door to look at it. after further explanation the people from the transmission shop they said it has a semi-manual transmission. i think that it is complete bull becuz the car has a clutch. however, on the slow painful drive home i noticed that i was able to shift gears into 3rd and 4th without the clutch.
Old Jan 5, 2010 | 07:03 AM
Blue Dream's Avatar
I drove ttrank's car solo
What are you asking??
Old Jan 5, 2010 | 01:23 PM
furry35's Avatar
First is there really a semi manual transmission on the 03 and second what is good replacement clutch?
Old Jan 5, 2010 | 01:58 PM
parhamm1's Avatar
WTF is a semi manual transmission???
Old Jan 5, 2010 | 02:06 PM
furry35's Avatar
its basically where you are able to shift the gears without the clutch, but if you have that transmission on a car, there is no clutch pedal. its like the triptronic transmission
Old Jan 5, 2010 | 03:50 PM
dineth00i30's Avatar
Isn't that something like Dual Clutch transmission?
Im pretty sure your transmission is not sem-auto or what ever the BS they told you.
Take it to as different shop that know there way around a G.
Old Jan 5, 2010 | 06:49 PM
smash's Avatar
Yea dude this is a regular 6spd with clutch. It's possible shift gears w/o the clutch but the timing has to be perfect otherwise you're in for a world of grinding. I would not recommend this.
What you need is a new clutch. Not sure for the G's but typically $600-$1000 installed.
Old Jan 6, 2010 | 02:06 AM
furry35's Avatar
k thnx for all the help.
Old Jan 6, 2010 | 02:39 AM
jibberjabbers's Avatar
A manual transmission similar to that of a semi-truck..
heavy, grabs late and notchy as hell. yep.
Old Jan 7, 2010 | 12:36 AM
Sanclementeg35's Avatar
i got act clutch heavy duty and act flywheel for a grand. and labor was 4 bills and that was cheapp!! 07 6speed coupe
wuppiedog
Engine - Exhaust
Sep 6, 2015 12:07 PM
andrewvk
Interior
Aug 6, 2015 05:51 PM
TurboEE
Jul 31, 2015 10:41 AM
Buggzb86
Drivetrain
Jul 25, 2015 11:22 PM
