Throttle Body
Old Jan 5, 2010 | 12:15 PM
_dus10_'s Avatar
Throttle Body
2004 5AT
I Cleaned the throttle body yesterday(really needed it)
After cleaning it.. started the car and it seems to be idleing a little bit higher than before (just barely) but i think this was due to it being dirty before and having a "hard time opening," and mabe now its right now.. IDK?
So I drove the car for about 20 min.. then the "service engine soon" light came on.. Not what?
So any advice you might have on these issues will help..
Thank you
Old Jan 5, 2010 | 12:33 PM
SxExCx's Avatar
Here ya go:
Please read all instructions and be familiar with them before any attempts.
A stop watch or an analog clock with a second’s needle will be useful.
ECU Resetting Procedures
Timing is extremely critical. If it is NOT DONE within the specify time, the ECU will not reset and the Check Engine Light (CEL) will continue to remain ON.
Operations Procedures
1. Confirm that accelerator pedal is fully released, turn ignition switch “ON” and wait 3 seconds.
2. Repeat the following steps (2a and 2b) procedures quickly five times within 5 seconds.
2a. Fully depress the accelerator pedal (HARD).
2b. Fully release the accelerator pedal.
3. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 10 seconds until the CEL starts blinking.
4. Fully release the accelerator pedal (while the CEL is still blinking)
5. Wait about 10 second.
6. Fully depress the accelerator pedal and keep it for more than 10 seconds.
7. Fully release the accelerator pedal (The CEL light will continue to blink).
8. Turn ignition switch to “OFF” position and now you can start the car. The CEL light should be gone.
If the CEL light continues to remain ON, repeat the above steps. Timing is EXTREMELY critical to resetting the ECU.
Accelerator Pedal Release Position Learning
Operation Procedure
1. Make sure that the accelerator pedal is fully released.
2. Turn ignition switch “ON” and wait at least 2 seconds.
3. Turn ignition switch “OFF” wait at least 10 seconds.
4. Turn ignition switch “ON” and wait at least 2 seconds.
5. Turn ignition switch “OFF” wait at least 10 seconds.
Throttle Valve Closed Position Learning
Operation Procedures
1. Make sure that accelerator pedal is fully released.
2. Turn ignition switch is “ON”.
3. Turn ignition switch is “OFF” wait at least 10 seconds.
Make sure that the throttle valve moves during above 10 seconds by confirming the operating sound.
Idle Air Volume Learning (Throttle Position Learning)
It is better to count the time accurately with a clock.
1. Perform “Accelerator Pedal Released Position Learning”.
2. Perform “Throttle Valve Closed Position Learning”.
3. Start engine and warm it up to normal operating temperature.
4. Turn ignition switch “OFF” and wait at least 10 seconds.
5. Conform that accelerator pedal is fully released, turn ignition switch “ON” and wait 3 seconds.
6. Repeat the following (steps 7a, 7b) procedures quickly five times within 5 seconds.
7a. Fully depress the accelerator pedal (HARD)
7b. Fully release the accelerator pedal.
8. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 20 seconds until the Check Engine Light (CEL) stops blinking and turned ON.
9. Fully release the accelerator pedal within 3 seconds after the CEL is ON.
10. Start engine and let it idle.
11. Wait 20 seconds.
12. Rev up the engine two or three times and make sure the idle speed and ignition timing are within the specifications.
Old Jan 5, 2010 | 03:33 PM
_dus10_'s Avatar
What if I did not do this and drove the car for about 20 min. Should I go and do this now before I try to drive it again?
Old Jan 5, 2010 | 03:39 PM
SxExCx's Avatar
yes, you need to reset the TB for the light to turn off and the TB to function properly.
Old Jan 6, 2010 | 06:21 AM
_dus10_'s Avatar
thanks
Old Jan 6, 2010 | 03:47 PM
DUS10's Avatar
it says fully depress the acceleration for more than 10 sec, the another time for 20 sec.. wont that blow up the engine?????
Old Jan 6, 2010 | 05:01 PM
Agent F's Avatar
Pretty sure the engine isn't on when this is done, just key turned to start the electronics in the car lol!
Old Jan 6, 2010 | 05:08 PM
SxExCx's Avatar
Lmao!
Old Jan 6, 2010 | 07:27 PM
Blue Dream's Avatar
I drove ttrank's car solo
That is classic, definitely sig worthy!!
Old Jan 6, 2010 | 08:19 PM
SxExCx's Avatar
^it doesnt work out of context
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
g.spot
May 9, 2016 10:54 PM
prinny
Nov 22, 2015 11:07 PM
Usman Ali
Oct 4, 2015 08:23 PM
NyCrAzY
Oct 1, 2015 09:19 AM
