Intake sound questions...
Old Jan 15, 2010 | 06:39 AM
Blue Dream's Avatar
I drove ttrank's car solo
Originally Posted by kako
^^^^^^ Something doesn't make sense about the design of the R2C. Isn't the air scoop being blocked by the Heat shield ?
I just need to take the front scoop off. The R2C pulls from the bumper and under the hood where the stock airbox pulls from. The box needs to go up to the hood to prevent heatsoak on that side.
If you just cut out the side to get air from the scoop, it would have to be sealed in order to prevent sucking hot air into the intake.
Old Jan 15, 2010 | 11:15 AM
kako's Avatar
I always assumed that the majority of air intake is actually from the bumper / hood area, but the stock air box definitely get's some air from the air scoop. How much ?, I'm not sure.
Old Jan 15, 2010 | 11:54 AM
LightsOut's Avatar
SIETESG
You could go with the R2C like I have. Best of both worlds: great sound and flow but seals against the hood for little to no heatsoak. Draws air the same way the stock box does.
the intake you have is for the 350z... the one I have is for the g35. my intake doesnt have the heat shiled blocked off like yours. R2C sent me the one you have before but I knew it was wrong, so they sent me the correct one.
Old Jan 15, 2010 | 11:56 AM
LightsOut's Avatar
SIETESG
if you want to see how the shield should look pm
R2C intake is the best! no heat soak and you get the sound as well.
Old Jan 15, 2010 | 11:57 AM
LightsOut's Avatar
SIETESG
here what it should look like. first pic
https://g35driver.com/forums/engine-...e-intakes.html
Old Jan 15, 2010 | 12:16 PM
PAIXAO's Avatar
I have the Stillen CAI and I have not one complaint.
Old Jan 15, 2010 | 12:20 PM
Blue Dream's Avatar
I figured that out when they sent it, but after looking at your pictures and playing around under the hood, I decided to keep this one. I like how it completely seals against the hood on 3 sides and only draws air from the front.
Even though you're box is getting air from the scoop, I would be afraid it still pulls in a little hot air from the engine bay.
Old Jan 15, 2010 | 12:34 PM
LightsOut's Avatar
SIETESG
fitment is so tight that the snorkle and shield are pressed against eachother. But either way it shouldn't make a difference. this intake
Old Jan 15, 2010 | 06:21 PM
Blue Dream's Avatar
Originally Posted by LightsOut
this intake
Couldn't agree more.
Old Jan 15, 2010 | 07:21 PM
Bri127mx's Avatar
I have the Stillen Z-tube, and Stillen Hi-Flow Intake... Definately a deeper growl when winding it out, quiet when driving normal (with the exception of the whisting sound a little louder i guess from the z-tube having no baffles), and it seems to work better than stock (noticed a littleee difference in power, but maybe its just in my head), it fits in place of the stock system, and keeps a somewhat stock appearance.
If I were to get another G, I would def. get the Stillen Z-tube and Hi-Flow Intake all over again.
Old Jan 29, 2010 | 02:20 AM
herrschaft's Avatar
Headers, HFCs, cat-back exhaust, CAI:
Won't be a deep rumble sound but it will definitely be louder!!!
http://www.youtube.com/watch?<br /> ...ayer_embedded#
Old Jan 29, 2010 | 10:37 AM
ConradoR's Avatar
Vid not working
Old Jan 29, 2010 | 05:36 PM
Blue Dream's Avatar
haha got this message. "The URL contained a malformed video ID. "
Old Jan 29, 2010 | 08:28 PM
herrschaft's Avatar
Vid not working
The sh*t worked yesterday
Just google/youtube "Palomar Julian run 8-15-09 pt 3", You'll see the back of a white G35. The exhaust note is only in the first minute or so.
Old Jan 30, 2010 | 06:01 PM
  #30
archman44's Avatar
how does the revup oem airbox with drop in K&N compare to the JWT Pop charger or the
stillen CAI. and why doesn't anyone talk about the K&N CAI which pulls air from below.
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
SePa_8310
Sep 16, 2015 04:32 AM
HellaG35
Intake & Exhaust
Sep 8, 2015 10:02 PM
