Need custom wheel help Please!
Old Jan 16, 2010 | 06:16 AM
logg's Avatar
Bought a set of TRW Thruxtons for my G coupe. The are staggered 8.5X20 front and 10X20 rear. I bought them used from a guy that had them on a G35S sedan. I went to put on my fronts and they will not pass my Brembos. Went to a wheel shop and they tried a 1/4 spacer and that would take car of it. Now the problem is the wheel studs are too short to mount the wheels. Can I get longer wheel studs installed? Would it be safe? Any other suggestions? The guy I bought from and the Infiniti dealer both said these wheels would fit and now I'm pissed. What can I do? Am I out $1000 for wheels and tires? Thanks
Old Jan 16, 2010 | 06:19 AM
GeezNuts's Avatar
i think you mean TSW...
You can get extended studs and if installed properly they will be safe - you will likely need to run an open ended lug nut though to get them tight against the wheel.
Other suggestions would be to make sure before buying - perhaps test fit next time if unsure.
Old Jan 16, 2010 | 10:09 AM
G2FLIP4's Avatar
everything
Buy some spacers with the studs already in them, then short stubby nuts go on your stock studs but theyre countersunk into the spacer so they are flush for the wheel to sit on
Old Jan 16, 2010 | 11:22 AM
logg's Avatar
What size spacer? I would have test fitted these if they didn't come off of another g35. Everyone said they would be a direct fit. Guess they were wrong.
Old Jan 16, 2010 | 12:55 PM
GeezNuts's Avatar
Touche!
jsimonk
Dec 22, 2023 03:49 PM
Team STILLEN
Aug 10, 2015 08:17 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
THMotorsports
Midwestern
Jul 22, 2015 10:27 AM
