aftermarket rims and tires.
Old Jan 23, 2010 | 05:49 PM
whoisthis's Avatar
i will taking out some air..
well, i need to buy front tires almost every year because my damn g35 has alignment problem that cannot b fixed -_- i think all other g35 has this problem too haha
Old Jan 23, 2010 | 06:47 PM
ttknf's Avatar
This thread is kind of moot. You neglected to specify what kind of temp/weather conditions you are driving in currently, and whether or not your tires are of the summer or all-season type.
Higher inflation pressures reduce rolling resistance slightly and typically provide a slight improvement in steering response and cornering stability, so this is something to be taken into account. Conversely, higher pressure sometimes leads to a harsher ride.
If you currently live in an area that's experiencing cold temps, and you're dumb enough to be running summer tires, you might want to underinflate by a few psi to help build up internal temps and keep the tires at a safe operating temp. If you're running all seasons and it's cold, run around the 35 psi that everybody suggested. If you're in a consistently warmer climate, stick to around 35 psi for any type of tire. If you intend on taking the car to the track or you're gonna hot rod it on the back roads, add a few pounds to the 35 psi and you'll increase your steering response and turn-in a bit.
Old Jan 23, 2010 | 07:25 PM
LightningRod's Avatar
I'm at 32
jilljann1
Jul 21, 2020 08:12 AM
ZoominG35
19 Inch
16
Oct 30, 2015 05:44 PM
alessandro
Oct 8, 2015 09:29 AM
Albanian122
Sep 7, 2015 07:41 PM
