aftermarket rims and tires.
Old Jan 23, 2010 | 03:51 AM
whoisthis's Avatar
i have a 06 G35 coupe with after market rims and tires. The rims are from niche.
My tires are really low profile. i dun remember exactly but it's about 2~3 inches.
i have a question about tire pressure. On the tire wall, it says the psi should be 51. But then i saw my brother's car's tires and they say 51 psi also. But on the front door decal it says max psi should be 31psi..
So i'm guessing the tire pressure on my tires shouldn't be 51 psi. I put about 42~43 psi for now.
How much should i put in??
Old Jan 23, 2010 | 04:02 AM
kennymo's Avatar
that 51 is MAX.
i run mine between 35-40
Old Jan 23, 2010 | 04:09 AM
whoisthis's Avatar
Originally Posted by kennymo
that 51 is MAX.
so u basically subtract 10~15 psi from what it says on the tire wall for any tires, right?
Old Jan 23, 2010 | 04:11 AM
kennymo's Avatar
well when i worked at a tire shop i always put that much in. unless it was a big truck. then i put in 45-50
Old Jan 23, 2010 | 04:20 AM
whoisthis's Avatar
it seems like i put too much in lol..
should there b different amount of psi in low profile and normal profile?
i think there should be more psi in normal psi than low profile.
Old Jan 23, 2010 | 09:38 AM
gary c's Avatar
In your manual and on your drivers door there's a sticker that reads 35 PSI. If you run anything above 37 to 40 you'll wear out the centers of your tires. What you see on the sidewall of your tires in the maximum PSI allowed, that doesn't mean you should run that amount....ever!
Gary
Old Jan 23, 2010 | 12:40 PM
eurodre's Avatar
unless your tires are stretched then stick with the oem suggestion
Old Jan 23, 2010 | 12:43 PM
elperuano's Avatar
my tires r stretched...i put 40 psi on mine
Old Jan 23, 2010 | 04:56 PM
whoisthis's Avatar
Gary
my tires are aftermarket which have very low profile. Since they are low profile, i think they are stretched. i bought a used g35 with the low profile tires so i dun know exactly about the tires.
i heard someone saying put 44psi or MAX.
Old Jan 23, 2010 | 04:58 PM
eurodre's Avatar
^^no... just because they are low profile they are NOT necessarily stretched
would you just put 35 already?
Old Jan 23, 2010 | 04:59 PM
whoisthis's Avatar
do u have any specific manual u go by, or u just put 40 psi?
i put 42~43 psi...
Old Jan 23, 2010 | 05:07 PM
LordFappington's Avatar
35 is standard for most vehicles.
Old Jan 23, 2010 | 05:09 PM
eurodre's Avatar
this thread is failing quickly
Old Jan 23, 2010 | 05:18 PM
whoisthis's Avatar
lol sry. let's stop the thread here lol
Old Jan 23, 2010 | 05:30 PM
gary c's Avatar
i put 42~43 psi...
Your G35 came with a manual, s/b in the trunk in that black case.... One more time, if you drive a G35 coupe or sedan your tire pressuer s/b 35 PSI. We all have low profile tires, some more than others but the tire pressure remains the same....Hello 42/43 is way to high unless you enjoy buying tires every year and having a crappy ride.
Gary
