G35 coupe 05 automatic transmission oil change
Old Jan 23, 2010 | 06:40 PM
g35ladyram's Avatar
Hey guys,
Please help! My g35 has 60k and have never done transmission oil change on it. Can someone please tell me what kind of oil I should purchase? how many quarts? what brand? Any input will be appreciated.... thanks guys!
Old Jan 23, 2010 | 06:59 PM
04ScoupeAT's Avatar
it uses Nissan J matic fluid if i remember correctly mine has yet to be changed an im at 62k! so I as well am looking for answers to ur ?'s
Old Jan 23, 2010 | 07:15 PM
gary c's Avatar
Our 5AT requires 6 quarts and I believe it's supposed to be changed every 30 K miles, you're a little late! Now you're out of warranty I'd buy 6 quarts of Red Line synthetic AT fluid since you've neglected your trans it's time to treat it right. This will make your trans shift smoother too....G/L
Gary
Old Jan 23, 2010 | 08:45 PM
JUM3's Avatar
i woudln't use anything but Oem spec.
Old Jan 23, 2010 | 09:58 PM
Blue Dream's Avatar
I drove ttrank's car solo
Gary
Actually the transmission holds 10 3/4 quarts. The 30,000 and 60,000 mile services call for a drain and fill which takes about 3 1/2 quarts to do.
OP what I would do is buy 8 quarts, drain the pan, and refill with 3 1/2 quarts. Drive 50-100 miles and repeat the process. Give the car about 1-2000 miles and repeat. That way you don't shock the tranny all at once with new fluid. I don't think the tranny has been hurt unless you track your car but check your fluid ASAP. If it is dark or brown and smells burnt, you probably need to ignore my first advice and take it to the dealer for a complete flush and fill.
The tranny fluid is Nissan S-Matic, it replaced the J-Matic and is the only transmission fluid recommended for our engines.
Old Jan 23, 2010 | 10:28 PM
04ScoupeAT's Avatar
Gary
well i know its overdue lol but i still have warranty so ill be up there soon..just waitin on Taxes!
Old Jan 23, 2010 | 10:44 PM
bigc's Avatar
Wings Nation
what he said
vmcarbuyer
Oct 12, 2019 12:42 PM
ClwMike
Jul 23, 2015 12:55 PM
brian_z
Jul 20, 2015 01:30 AM
AustinErkl
Drivetrain
Jul 18, 2015 05:44 PM
newbdriver01
Jul 15, 2015 06:10 PM
