help: "set" light flashing on the cruise control
Old Jan 25, 2010 | 11:37 PM
JUM3's Avatar
so i got off the freeway and was using cruise control the entire way. When i hit local, the "set" indicator on the cluster started flashing rapidly. Ive never seen this before. So i turn the cruisecontorl switch off and on. It still flashes. I have turned the car off and on and it's still there. Im afraid it might be a warning light so I havn't tried to set the mph at all. anyone know what's going on?
TIA
Old Dec 24, 2010 | 02:47 PM
RDUBPhoto's Avatar
Same thing is happening to me now. Did you find a fix for this?
Your help would be much appreciated!
Old Dec 26, 2010 | 04:38 PM
JUM3's Avatar
no fix.. it comes on one every other month. or something like that.
Old Dec 27, 2010 | 01:27 PM
RDUBPhoto's Avatar
That answer doesnt work for me. I will find out whats going on.
My guess is 1 of 2 things.
1. Moisture on ECU. My passenger side has been leaking a bit and I just recently siliconed the entire pass side to prevent the ECU from getting any more wet.
2. Something with the TPS or Throttle body. My Slip light has been going off when I'm in traffic and don't come to a complete stop and then start back up. Slip activates around 1000 RPM and then goes away.
Old Dec 28, 2010 | 02:51 PM
RDUBPhoto's Avatar
Ok so I believe I fixed the issue.
I took off all the plastic covering the battery and pass. cabin filter. First I wiped it all down and used a blow dryer to make sure it was all dry. Then I took regular 100% silicone and calked the main wires that lead into the interior, the cabin filter area, and any crack where the water could get into the interior. Bad design if you ask me. Anyways, after a couple of days it dried out and now works fine. Cruise sets, no blinking and now issues.....
Old Dec 28, 2010 | 03:18 PM
JUM3's Avatar
oh god... I remember I jabbed a whole in the rubber leading from the battery through the firewall during my sub install... I might of not put enough silicone..
But i think you might of found the problem
Old Dec 28, 2010 | 03:44 PM
RDUBPhoto's Avatar
Same thing I did. But make sure you silicone the entire outside edge of the rubber surround too. I siliconed my amp wire and that wasn't enough....
Also clean it up really well first and dry it for a while with a blow dryer. Has to be dry for the silicone to adhere...
Hasanbaloch
Feb 29, 2024 08:45 PM
Luisgalvan33
Jul 19, 2018 08:16 PM
derres
Aug 28, 2015 03:27 PM
ghost_g35
Aug 7, 2015 10:31 AM
Luisgalvan33
Jul 28, 2015 05:37 PM
