Super urgent, brake lights are out
So, i noticed a week ago that the center brake light was out. A few days ago, i noticed it was working again. Now i thought i just didn't see the light because there was too much of a reflection from the sunset. last night, i saw the center light was indeed out.
I thought this meant that a plug was loose in the back. So i climb in the back, rummage around and find how to take the center light off. I play around with it, have the pedal held down and test the plug poles for and current... nothing. so the wiring issue is further down. I decided not to do anything about it and have it checked out. then, as im packing everything up, i go to move the car, i feel a click in the brake pedal and notice the abs, slip and vdc-off lights not clearing. I back the car up to the garage door to see a reflection from the brake lights. nothing.
So now my brake lights are out, and tomorrow is monday. great. any help would be appreciated.
-Zach
-Zach
Don't know if this will help, but in my previous car (Maxima) I had the same problem. Turned out to be a dead ignition switch.
Probably not your issue then. Sorry I couldn't be more help.
Did you check all of your fuses? Maybe blew one poking around the 3rd brake light?
netcbc
Wheels & Tires CDN
Aug 25, 2015 09:42 AM
